another overheating thread - JeepForum.com
post #1 of 7 Old 06-09-2009, 06:15 PM Thread Starter
ajhgoodwrench3
i have a 94 grand cherokee, i just bought it today and it only needs a windshield and a power steering hose and i got it for 400 bucks with 155,000 miles it is the 4.0 andi was driving home and i notiched the temp gauge started to go up very slowly, so i have spent my day trying to find the culprate the water pump is new within 10,000 miles, i pulled the stat and that is brand new, overheated even faster with the stat out, so i put it back in and then i bypassed the heater core and that also didnt work, i can let it idle for any amount of time and it will not overheat, but if i rev it to 2500 rpms while in park for over 30 seconds i notice the temp going up, and if i drive down the road it goes up all the way to the orange line but if i pull over and let it idle it will cool back down, can anyone help me, i have waisted my whole day and have gotten nowhere
ajhgoodwrench3 is offline
post #2 of 7 Old 06-09-2009, 06:18 PM
WhiteOut
WhiteOut's Avatar
There is an overheating thread 5 posts down, there is a search button at the top of this page. Use them! : Puctuation, its not a foreign language.
WhiteOut is offline
post #3 of 7 Old 06-09-2009, 06:28 PM Thread Starter
ajhgoodwrench3
im not retarded nor am i new, my overheating is different than any other thread on here my truck only overheats when driving, if you want to be cool and make someone look like an *** you might just want to look in the mirror before you you try to find one on here
post #4 of 7 Old 06-09-2009, 06:46 PM
WhiteOut
WhiteOut's Avatar
Did you look to see if the fan clutch is still good? Is there foreign material in the fins on the rad? There are not many things different between overheating threads.
WhiteOut is offline
post #5 of 7 Old 06-09-2009, 06:53 PM
Steve98
I agree its not that different. Plenty of jeeps overheat only when driving. Is the Tstat the right temp? If its lower than stock, that can allow to much water flow and not allow for substantial time for the water to cool in the radiator. That would be made worse by driving, increased RPM. Also a stock radiator with that many miles could be clogged even with regular maintenance.
Also are you sure its overheating? Can you hear boiling or see it in the overflow tank? Check/replace the cap too.
2006 LJ Rubicon
Steve98 is offline
post #6 of 7 Old 06-09-2009, 06:54 PM Thread Starter
ajhgoodwrench3
the fins are all falling apart
post #7 of 7 Old 06-09-2009, 07:00 PM
WhiteOut
WhiteOut's Avatar
You just solved your own problem.
WhiteOut is offline
Another Overheating Thread! NewJeepFever ZJ Grand Cherokee Forum 48 09-27-2008 05:49 AM
More Overheating ?'s reesycup ZJ Grand Cherokee Forum 3 06-13-2008 12:59 PM
One day of overheating adgjqetuo ZJ Grand Cherokee Forum 4 06-12-2008 07:21 AM
00 Wj Overheating (no Fan) Death-Mobile ZJ Grand Cherokee Forum 3 08-29-2006 07:48 PM
'00 Wj Overheating / No Fan jondilly1974 ZJ Grand Cherokee Forum 9 08-09-2006 10:56 PM
