Another High Idle Question (have read a few..) - JeepForum.com
post #1 of 11 Old 08-20-2012, 11:36 AM Thread Starter
seanom
So I get high idle in park and neutral only after driving for a little while. I also have been getting a hard start.
High idle happened for about a week, then hard start, so I cleaned the Throttle Body and the AIC with cleaner and also sea foamed the engine. I threw some fuel injector cleaner in a full tank too.. just for fun.
Problem went away for about 2 weeks and now is back, maybe even a little worse.
Mainly wondering why being warm would create the High Idle; it only hard starts when cold (kindof obvious)
2 more things: the exhaust system fell off while on the highway (during problems, before cleaning), so cat muffle etc..
and I haven't reset the trouble code yet- was going to do that today, but forgot my laptop at a buddies.
I think most likely its the TPS or AIC does TPS make for a hard start? It seems strange that the high idle doesn't come on until after Iv'e been driving instead of right away.
seanom is offline
post #2 of 11 Old 08-20-2012, 05:18 PM
ZeeJay1997
May be caused by a leaking intake manifold gasket. Throws the MAP sensor off.
ZeeJay1997 is offline
post #3 of 11 Old 08-21-2012, 06:41 AM
gothchick
My vote is on TPS. Dealership can run a scan tool on it to check voltage range. They generally don't charge for little stuff like that.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #4 of 11 Old 08-21-2012, 07:47 AM
Canyon411
You mentioned your exhaust is gone, what about the 02 sensors? Are they missing as well?
Canyon411 is offline
post #5 of 11 Old 08-21-2012, 10:37 AM Thread Starter
seanom
I put it back on; but I am wondering alittle if that 02 sensor could have been damaged causing some of these results.
I wish I didn't have to.. damn that thing is loud without a muffler or cat
It's too loud when the sound is coming from under your feet tho
seanom is offline
post #6 of 11 Old 08-21-2012, 10:39 AM Thread Starter
seanom
I checked for vacuum leaks with started fluid, couldn't find any - I was mainly checking the hoses tho.
seanom is offline
post #7 of 11 Old 08-21-2012, 10:40 AM Thread Starter
seanom
Cool - Ill give em a call or see if I have the equipment kicking around here
seanom is offline
post #8 of 11 Old 08-21-2012, 04:59 PM Thread Starter
seanom
I just ran codes and got P1294 (comes on and off it seems) as well as P0138 (02 sensor Cir. High. Volt.)
I'm going to try clearing them as I haven't since the exhaust fell off and I cleaned everything
seanom is offline
post #9 of 11 Old 09-02-2012, 12:03 PM Thread Starter
seanom
so I just went ahead and bought a new TPS, everything is still the same... Hard start is worse. I cleared the codes after the install. I couldn't clean the MAP becasause the damn aircon was in the way. Gonna rip that out soon.
Any ideas? would O2 sensor after the cat make for a hard start?
seanom is offline
post #10 of 11 Old 09-03-2012, 08:52 AM Thread Starter
seanom
bump...
seanom is offline
post #11 of 11 Old 09-03-2012, 08:13 PM
gothchick
Hard start may be as simple as a good ol' fashioned tuneup...
hard start , high idle , iac , tps , zj
pcm problems/rough idle/cel light codes. sound familiar, please read ktmjoe15 ZJ Grand Cherokee Forum 10 04-11-2012 12:06 PM
why does my display read lo even in high? volksman ZJ Grand Cherokee Forum 3 10-23-2008 10:58 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 07:43 AM
Idle Jumps High After Sitting at Idle gunthagunth ZJ Grand Cherokee Forum 0 09-21-2006 08:58 PM
Harsh idle and vibration, please read. mrj7500 ZJ Grand Cherokee Forum 3 10-01-2004 06:15 PM
