Another "clunk" thread - ignore the noise? (2004 WJ) - JeepForum.com
post #1 of 6 Old 03-27-2009, 08:53 PM Thread Starter
JustSomeDude
So with my 2" BB installed, I found a "clunk" sometimes occurs from what appears to be the right-rear wheel area. Now, before you go talking about torquing bolts, etc., be aware that this clunk existed BEFORE I installed the lift. At first I thought it was just the stock shocks blown out - but since it persists, I am very confused.
I can confirm that the rear shock mount and linkage bolts are torqued perfectly to spec. The coil was seated properly, and everything with the lift was in order. As for the sound, it will not occur with any normal bump, deep pothole, etc. It almost requires 2-to-3 consecutive bumps in the road to get the rear rocking. Even then, it's not a loud CLUNK, it's almost a subtle "thud"... and when I go over multiple bumps it sounds like a "wobble". I'm sure this isn't making any sense, but I'm wondering if some one could suggest where I should begin...
Or should I just ignore the sound??
2004 Jeep Grand Cherokee Laredo
3" IRO Lift Kit | Bilstein 5125 Shocks | JKS discos | JKS BPEs | IRO Adj Track Bar
Goodyear Duratrac 265/75/16
JustSomeDude is offline
post #2 of 6 Old 03-27-2009, 09:06 PM
Pomorza
When does this "clunk" occur? I had a similar "thud" noise with my ZJ (completely stock) and the U-joints were shot.
1996 Jeep Grand Cherokee. I6 2WD auto 250,000+ miles.
Pomorza is offline
post #3 of 6 Old 03-27-2009, 11:01 PM Thread Starter
JustSomeDude
It's *usually* when hitting a few moderately sized bumps right in a row, and the back gets a little rocked around. If I do single bumps - like run over a curb or something - it doesn't happen. I have to down an alley with a schitt ton of potholes, or something, at a good speed to get it to occur. But it's definitely coming from the rear, and sounds like rear-right.
post #4 of 6 Old 03-28-2009, 12:02 AM
PJNovinskee27
DUDDDE. same thing is happening in my 01 WJ. so ya id love to know why. its the same thing with mine... i need consecutive liie little bumps .... and its in my right rear and i tighted the shock bolts really well so i have no diea. and the rear bushing seems okay.
Paul
01 TJ. Mostly stock. lifting soon
PJNovinskee27 is offline
post #5 of 6 Old 03-28-2009, 01:03 AM
AgitatedPancake
check out your control arm bushings on the side the sound is coming from, and I know the balljoint in the upper rear a-arm starts clunking annoyingly when it gets worn out.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #6 of 6 Old 03-30-2009, 11:15 AM Thread Starter
JustSomeDude
I was just about to say... this is the EXACT same sound I had on my Explorer when the balljoints were shot. Cripes... another drop in the bucket!!!!
Window makes "clunk" noise when rolled down. thirteen ZJ Grand Cherokee Forum 1 04-19-2009 10:08 AM
3" IRO Lift kit yes or no? ignore my other one PJNovinskee27 ZJ Grand Cherokee Forum 8 05-07-2008 10:16 PM
"Clunk" from rear axle area JarheadBoom ZJ Grand Cherokee Forum 11 11-20-2007 02:14 PM
Another "whining noise" thread XJWJfan ZJ Grand Cherokee Forum 0 12-20-2005 11:14 AM
Steering making "clunk" when turning? nate438 ZJ Grand Cherokee Forum 10 09-19-2005 10:14 PM
