another AC thread. - JeepForum.com
post #1 of 6 Old 07-18-2007, 11:43 PM Thread Starter
sandman
another AC thread.
ok so i found out what my problem is, the compressor wont kick on. if i wire a constant on the plug that connects to the evap can thing it turns on and stays on but besides that it wont come on. so what do i need? im guessing that i dont need a new compressor right?
1993 Jeep ZJ. 4.0
sandman is offline
post #2 of 6 Old 07-19-2007, 12:57 AM
Dalmask
That plug plugs into the pressure switch for your system. If the freon is low in your system, the switch keeps your compressor from spinning to avoid damage to the compressor. What you'll need is a freon fill kit with a pressure gauge. It's pretty simple from there on out, just follow the instructions.
Ryan
Dalmask is offline
post #3 of 6 Old 07-19-2007, 01:14 PM
alivenkickin28
Yeah if you jump the plug and it comes on its more than lkely out of freon -- being that it is a 93 you may be looking at bad evaporator -- when you gas it back up get in and see if you can smell a "gas" smell inside coming out of the vents -- if you can -- thats your problem - if not possibly the accumulator or even the low pressure switch can have a leak -- the accumulator is pretty cheap -- 100 bucks with hoses at Napa -- evap bout 120 -- but its a pain in the ASSSSSSSSSSSS to change out -- good luck!
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #4 of 6 Old 07-19-2007, 07:07 PM Thread Starter
sandman
is it possible that its too full? i just filled it and i have a hunch i put a bit too much in.
1993 Jeep ZJ. 4.0
sandman is offline
post #5 of 6 Old 07-19-2007, 08:17 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Did you jump the compressor when you filled it? I think the compressor has to be running in order to add. Could be wrong though.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 6 Old 07-20-2007, 04:57 AM
SnaFu2
No, u r right. compressor must be running to recharge. jumping low pressure switch will make compressor run if u r low on freon. make sure to purge line from guage to port before u add freon, otherwise u r sending a shot of air into system. not good!
without compressor running u will most likely show a too high pressure reading on guage. mine cycles on and off when low, i just give it a shot or two when it cycles on and compressor will stay running, and blow cold air.
a side question. has anyone had problems with the low pressure switch. if so, how hard is it to change out? i ask, because as soon as i jump it out i have cold air and i only have to give system a couple of short shots of freon (way less the a lb.) before low pressure switch is satisfied.
SnaFu2 is offline
First thread and really need some help please crgeltn ZJ Grand Cherokee Forum 19 12-10-2009 01:16 PM
Yet another CKP Thread grw800 ZJ Grand Cherokee Forum 3 10-01-2009 07:15 PM
thread gone ? retroron ZJ Grand Cherokee Forum 4 04-07-2009 08:46 PM
Another IRO LA Thread.... nierace ZJ Grand Cherokee Forum 50 05-20-2007 09:54 PM
VS. thread i have 5 jeeps ZJ Grand Cherokee Forum 14 04-11-2005 07:55 PM
