Another 98 ZJ Side view mirror question - JeepForum.com
post #1 of 10 Old 07-24-2011, 09:25 PM Thread Starter
BL_Maros
I'll be getting a 98 zj limited 4.0 6l. One thing I need to replace is the drivers side view mirror. I do not want to replace the entire housing as it is painted to the color of the jeep. I'd really prefer to just replace the glass. even draining the diming fluid might be okay. can some one link me in the direction of a step by step thread for removing just the glass and maybe another for draining the diming fluid? (if there is a such thing).
Also is there a vendor link to somewhere i can buy JUST the glass?
thanks
BL_Maros is offline
post #2 of 10 Old 07-25-2011, 07:12 AM
MaintMech
Old and in the way
MaintMech's Avatar
Take a look at RatMonkey's build thread. I think he did that in there. Or maybe he posted it in a separate thread. I do seem to remember that someone on this forum did the fluid drain.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #3 of 10 Old 07-25-2011, 07:31 AM
JeepOrvis97
JeepOrvis97's Avatar
You face the mirror towards the ground and use a screwdriver to pry up on the mirror and it'll slide off the clips that hold it on, then there are 2 wires going to it for the dim feature. From there I'm not exactly sure how the black ring comes off the glass to get the fluid out but it might just be clipped, mine is broke so it came off easy. Then you take the front glass out and clean both the front piece of glass and the mirror glass, put them back together and then put it back on the Jeep. BTW, the dealer does not have the dimming glass anymore, I tried to buy one there and it was just a regular mirror for $80, I returned it before leaving the parking lot.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #4 of 10 Old 07-25-2011, 07:08 PM
savannahzj
I went to the jy and found a zj and proceeded to pull off the glass insert. After some careful prying and pulling I got it off. I figured if it broke it didnt matter and I would move on to the next one. There is a method to it, but I learned by doing it at the jy first, and then successfully on my zj. It was kind of tedious, but do-able. As for the oil, none I found at the jy were any good. So my driver's side mirror does not dim, but at least I can see out of it.
savannahzj is offline
post #5 of 10 Old 07-25-2011, 07:11 PM Thread Starter
BL_Maros
Yeahh I don't really care about dimming just need it to be clear. This is some gread advice though. Thanks guys! Ill def have to go to the jy first.
BL_Maros is offline
post #6 of 10 Old 07-28-2011, 03:49 PM
Cameleer
You can still get the auto dimming mirror from the dealer, just got one last week to replace the one on my 98 ZJ, it cost a little over $300 for the whole assembly. Itís $40 more if you just want the mirror glass part, so your better off getting the whole assembly.
They had it for me by the next day.
Only those who will risk going too far
can possibly find out how far one can go.
Cameleer is offline
post #7 of 10 Old 07-28-2011, 05:27 PM
JeepOrvis97
Well that's way too much money. Not sure why they couldn't get one for me at my dealer. They even used the vin to look for the mirror.
Current jeeps:
1997 ZJ Orvis
post #8 of 10 Old 07-28-2011, 05:41 PM Thread Starter
BL_Maros
Yeah that's an awful lot for a mirror. Id much rather just drain the fluid.
BL_Maros is offline
post #9 of 10 Old 07-28-2011, 07:34 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Creature comforts are a personal preference. Personally, with an idiot behind me with HID's I love the dimming. In my conversion I have one waiting to install and a spare.
coralman is offline
post #10 of 10 Old 07-28-2011, 09:19 PM
Cameleer
Before getting this high dollar mirror with a heater, pan, tilt, memory and auto dimming, I had looked at draining the fluid out and other options. If I where going the inexpensive way, I would just go down to the junkyard and pop the mirror part out of one that was non-dimming.
I don’t like those HID lights behind me either.
My 98 ZJ - 5.9 looks almost like new and most everything works with over 150,000 miles on it, and I want to keep it that way. And I do use it off-road too.
Cameleer is offline
Side-View Mirror Question Sporer65 ZJ Grand Cherokee Forum 4 05-11-2016 05:04 PM
What's going on with my side-view mirror? comishcraig ZJ Grand Cherokee Forum 7 11-09-2010 09:45 AM
side view mirror came off offhand_remark ZJ Grand Cherokee Forum 2 12-21-2007 05:08 PM
Aftermarket side view mirror? cocot ZJ Grand Cherokee Forum 1 11-26-2005 12:46 PM
Replacing side view mirror jagermeister ZJ Grand Cherokee Forum 1 02-04-2004 10:07 AM
