Another 3-4" lift thread - JeepForum.com
post #1 of 100 Old 03-19-2008, 09:58 PM Thread Starter
Davis87YJ
My 95 Grand Cherokee Build Thread
Ok Guys help me out here. I know it's been said before believe me I have searched and looked at every website I could find this week.
I have a 95 ZJ 4.0 and am looking to lift it 3-4". I'm trying to stay away from the budget boosts but if someone can persuade me otherwise I would consider it. I have a friend with some 32" BFG that I would get for nothing so I would like to be able to fit those and wouldn't care if I had to do a little trimming.
The Rough Country 4" caught my eye because it actually includes the control arms unlike what I see from everyone else in the same price range, it's $629.
http://www.roughcountry.com/jeep_zj-4.html
The Rusty's 3" kit seems very basic and would be be $440 with the cheap shocks.
The IRO 3.5" Kit seems to include a bit more than the rusty's kit, although it reuses your old from springs for the rear. It's $460
The RRO 3.5 or 4.5" kit seems a bit like the IRO as it's a F>R as well and runs $440-474, but I've heard there service is horrible.
The $600 range is at the top of what I would like to spend for the kit. I know I'll need an alignment afterwards and don't want it to be any more $1000 when all is said and done.
Let me know what you guys think.
Thanks,
-TIM-
Davis87YJ is offline
post #2 of 100 Old 03-19-2008, 10:24 PM
White_XJ1287
Iron Rock Offroad - Best Choice
White_XJ1287 is offline
post #3 of 100 Old 03-19-2008, 10:33 PM
Jones
Consider the following...
Jones's Avatar
Yes go with IRO. You shouldn't have to much trimming, mostly the front bumper and bending the pinch weld.
Jones is offline
post #4 of 100 Old 03-19-2008, 10:35 PM Thread Starter
Davis87YJ
So with the 3.5" IRO lift I can get away with using the stock CA's. I don't need anything not included in the kit for $460?
post #5 of 100 Old 03-19-2008, 10:37 PM
Sporer65
Sporer65's Avatar
Location: Powder Springs, Georgia/University of Tennessee
I would go with either the IRO kit and get a rear adjustable track bar or the RC kit and get adjustable track bars front and rear.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
Sporer65 is offline
post #6 of 100 Old 03-19-2008, 10:49 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
well with the IRO kit you would need to hunt down some front V8 springs, not I6 springs.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #7 of 100 Old 03-19-2008, 10:51 PM
FlipFlop425
Go with IRO you can't beat it for the price.
FlipFlop425 is offline
post #8 of 100 Old 03-19-2008, 11:02 PM
ickydoo
I just installed the Rough Country 4" lift last weekend and I love it. I'm running 33 x 12.5x 15 and all I had to trim was the front bumper and a little bit of the rocker panel. And smack the pinch weld with a BFH a couple times.
I'm glad I went with this kit because of the adjustable arms, allows you to move the rear axle back a bit to avoid any rubbing there, plus makes setting your pinion angle a breeze. Just so you know, there instructions suck big time, but its a pretty straight forward kit to install.
I did buy front and rear adjustable track bars from Kevins Offroad, just because I wanted more flex, and I'm not a fan of brackets. I highly recommend Kevins stuff.
It turns out I want to go an inch or 2 higher so I just ordered the front upper adjustable arms from Rough Country. They were only another 160 bucks, and will fix the pinion angle for the front.
As for the alignment, Just do it yourself and save some money. There is alot of info on here to show you, its quite easy and it doesnt take very long at all.
ickydoo is offline
post #9 of 100 Old 03-19-2008, 11:09 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
RRO - great company Read up on em: http://www.jeepforum.com/forum/f197/bad-rocky-road-offroad-rro-experience-441808/
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #10 of 100 Old 03-20-2008, 08:22 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I'm going to delta 9 you when I get home.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #11 of 100 Old 03-20-2008, 08:25 AM
ArloGuthroJeep
Mr. Hyde!
I don't swing that way Hunter
post #12 of 100 Old 03-20-2008, 12:04 PM Thread Starter
Davis87YJ
Ok, so if I go with the RC kit, for the adjustable track bars would I still install the Front and rear track bar drop brackets or since I would have the adjustable track bar I would mount them in the stock locations. So I would be looking at
Rough Country 4" lift kit $629
Front Adj Track Bar $139
Rear Adj Track Bar $139
Total-------- $907
IRO 3.5" Kit $459
Rear Springs since I have the I-6 $119
Reear Adj Track Bar $139
Total- $717 (No control arms w/ this kit)
for that matter should I be looking at the
IRO 4.5 Kit for $759
comes w/ F&R adj track bars, no control arms either.
T-case drop kit
Are the CA's that come with the RC kit any good, because that is what is steering me towards the RC kit. It looks like it's $499 for a full set of control arms from IRO, is there a cheaper place for those.
Are control arms really needed? got this from RRO website
You might ask about control arms. Many lifts have them... and boy don't those spiffy colors look pretty. The reality is that Jeep knew we'd be lifting these things and so built adjustability into the front end control arm mounitng system. Yes, with the stock control arms, you can have your vehicle set to 100% factory spec on alignment with the factory arms. The other shops won't be happy to hear thins since most money in suspension systems is made from pieces like the control arms (anything that is welded is a money maker for manufacturers) and not springs and shocks.
...While the truth may hurt them, it will set you free...
I was trying to stay around $600-700, but the price keeps jumping up here.
I should mention here that I probably wont be doing heavy duty offroading, I'm a hiker and backpacker. My truck is to get me to the trailhead and then thats where my fun starts. Some trailheads are a little harder to get to than others. I would like to have the ability to get to most places, but I won't be deliberatley crawling over rock cracks and boulders just for fun.
I still want to be able to fit the 32's though. Not wanting to skimp on things here, but it is for a 2nd vehicle that will only be driven 1-2 a month.
Thanks again guys, keep the info coming, I appreciate it.
-TIM-
post #13 of 100 Old 03-20-2008, 12:24 PM
ArloGuthroJeep
Mr. Hyde!
That is a crock of **** lie from RRO.
Don't use a crappy trackbar drop bracket. Especially since you plan on getting adjustable trackbars, there is no reason to. If you want to upgrade to the best possible trackbar system, check out www.kevinsoffroad.com and get his trackbar conversion. It'll upgrade you to a JKS trackbar and get rid of the stupid TRE on the stock trackbar that the ZJ's have. It'll also give you a very stout trackbar bracket.
Forget the TC drop kit - there is a 98% chance you won't need one.
As far as what you plan on spending I'll say this:
Dont' try and list a Grand Cherokee on the cheap.
Some people get lucky and need very little to lift their Jeep 4.5". Others need full sets of adjustable control arms & trackbars and replacement TRE's and DLE's etc...So if you plan on lifting that high and not doing the "full ball of wax" the first time out, be prepared and forewarned that there is the very real possibility you'll run into some issues and be required to spend well over your $600-$700 pricetag you have set for yourself.
post #14 of 100 Old 03-20-2008, 01:37 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
...While the truth may hurt them, it will set you free... "
That is the stupidest, most misleading, misinforming statement i have ever heard. How can they **** people over like that??
The factory CA's were designed for a lift height of 0". The more you lift it the more you are going to need aftermarket CA's. At 4.5" i really dont think you can get 100% factory specs on stock CA's.
Another thing, my "front end control arm mounting system" is stationary - it is welded to the axle and body. But when RRO shows me how i can easily adjust them i can decide to believe them.
post #15 of 100 Old 03-20-2008, 02:06 PM
BLU88
Word of advice from one newbie to the next. If you want to go on the cheap, look for other people's stuff when they upgrade. You can piece together a kit like I did and save a couple of bucks, but your downtime could be months. A complete kit is the easiest way to go. All the parts come in the box (most of the time) and you don't have to go to napa, advance auto, lowes, etc, for bolts, parts, etc etc etc. Lifting these things aren't cheap. If you want cheap, mount coil spacers and find up-country springs. That'll put you at ~3". You still need Adj trac bars (fr & rr) and shocks. And you're not going to find decent arms for less than 150/pair. A guy I know swaped in his rough country tj kit into his ZJ and loves it. It's his DD and his backup trail rig (his TJ has LA's, dana 60's etc, etc). Go with the rough country or IRO to get you started but get new trac bars to locate the axles.
Lurking and asking lots and lots of questions..........
__________
/__l_l_,\____\,____
l_---l_l__l----( )jeep( )
._(o)_)__(o)_)--o-)_)
BLU88 is offline
My Engine Swap "build thread" 4.0 - 5.2 redhatman ZJ Grand Cherokee Forum 52 06-30-2014 10:18 PM
ZJ/WJ Grand Cherokee "Build Thread" DIRECTORY EMTimZJ Grand Cherokee General Discussion 0 04-05-2009 08:38 PM
Another "clunk" thread - ignore the noise? (2004 WJ) JustSomeDude ZJ Grand Cherokee Forum 5 03-30-2009 11:15 AM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 05:26 AM
Another "whining noise" thread XJWJfan ZJ Grand Cherokee Forum 0 12-20-2005 11:14 AM
