Annoying Squealing noise under my hood!!!! - JeepForum.com
post #1 of 14 Old 10-31-2008, 12:40 PM Thread Starter
jerichof15s
2003 WJ
So i've got a 2003 JGC there's this squealing noise under my hood its been doing it for over a year now but only when it's COLD outside and above 40 mph. When I let off the gas its squeals really loud, and then I press the gas it stops. Only on some occasions I can get out pop the hood and catch it when its idle. I cleaned the entire intake it was really dirty and i changed my TPS (throttle position sensor) the only reason i changed that was because it was throwing a code and stalling on me. Well anyways i don't know if i've got a bearing out, pulleys or what? I've got an automatic tensioner on my jeep and you can't tighten it or any adjustments on it. So i don't know i'm just very frusterated with this entire noise. Also if i might have a bearing out how can i even tell there's ones going out? Thanks if anyone can help
jerichof15s is offline
post #2 of 14 Old 10-31-2008, 01:15 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
What kind of shape is the belt in? That's obviously the first thing to check.
You could take the belt off to check the idler pully. Those do go bad (normal wear item).
These squeals aren't always on the front of the engine, though...
I had a nasty squeal on my 4.0 that only made noise when the engine was cold, and only at certain RPMs...turned out to be the bushing in the distributor.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 14 Old 10-31-2008, 04:29 PM Thread Starter
jerichof15s
2003 WJ
yeah i replaced the belt already and i still have the problem i also noticed today it was about 75 degrees out when i was driving it was doing it again and usually it'll just do it when its colder out like 30's to 50 degrees. if i pulled out the distributer could i be able to tell if it is worn out?
post #4 of 14 Old 10-31-2008, 08:56 PM
steve L.
you know i had the same problem, and all i did was tighten it up a little, and no more squeal. i dont know if that would help, but its worth a try.
97' ZJ Laredo, I6, NP242
A Little Taste of Jersey Wheelin Of A 1997 & 1998 Jeep Grand Cherokee's For Your Enjoyment.
steve L. is offline
post #5 of 14 Old 10-31-2008, 08:58 PM
AgitatedPancake
tighten what up? As he stated atleast the 4.7's have spring loaded tensioners.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #6 of 14 Old 11-01-2008, 12:34 AM Thread Starter
jerichof15s
2003 WJ
How would i know if an automatic belt tensioner is even going bad? it looks fine when its in idle.
post #7 of 14 Old 11-01-2008, 01:06 AM
-Joe-
-Joe-'s Avatar
Any chance it does not do it when you have the A/C on and does it when your A/C is off?
If so look at your a/c clutch, it can squeal like mad when bad and your a/c is off.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #8 of 14 Old 11-01-2008, 09:32 AM Thread Starter
jerichof15s
2003 WJ
yup i checked it and it does it off and on
post #9 of 14 Old 11-01-2008, 01:28 PM Thread Starter
jerichof15s
2003 WJ
Does anyone think it may be a cracked exhaust manifold or gasket? i'm just throwing things out there that i think may do a whistling/squealing noise
post #10 of 14 Old 11-01-2008, 03:33 PM
Merc1973
Its the idler pulley/belt tensioner.......... very common to make noise when cold........
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #11 of 14 Old 04-21-2009, 10:13 AM
weber22h
answer to the squealing noise
I have a jeep sahara and i had the annoying squeal under my hood and i took it to two different mechanics and it ended up being a crack in my intake manifold.
weber22h is offline
post #12 of 14 Old 04-21-2009, 01:11 PM
sdowney717
I just replaced the idler pulley with a new bearing 4$
the idler pulley bearing is a 40 x17x12 MM a number 6203 sealed bearing.
Napa wanted 40$ for the pulley, autozone 16$, and I just bought the bearing 4$
at a bearing supply store. pop it out with a hammer and carefully put in the new one with a socket that presses across the whole face including the outer ring.
If you take off the serpentine belt and spin the pulleys, they should be quiet and smooth.
sdowney717 is offline
post #13 of 14 Old 08-18-2013, 06:59 PM
SpecialK2000
Idler pulley made need adjustment.
My jeep was doing the same thing. I went out there this morning....loosened up the idler pulley bolt, turned the adjustment screw clockwise brining the idler pulley towards the belt (i figured that would make the belt tighter).
No more squealing. It took no more than 5 minutes. Let's see how she sounds tomorrow morning.
Thanks everyone!
SpecialK2000 is offline
post #14 of 14 Old 08-18-2013, 08:01 PM
coltman151
holy old thread...
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
Squealing noise when releaseing the gas pedal?? Claudio58 WK Grand Cherokee & XK Commander Forum 3 08-11-2009 07:36 AM
strange squealing noise. kmb0427 ZJ Grand Cherokee Forum 7 01-26-2009 01:09 AM
Annoying Clicking under hood 20JeepGuy06 ZJ Grand Cherokee Forum 5 12-31-2008 03:00 AM
Squealing Noise: 2001 4x4 4.0L midd79 ZJ Grand Cherokee Forum 24 02-15-2008 06:49 AM
LOUD!!! Squealing Noise 95JpGC ZJ Grand Cherokee Forum 1 07-25-2006 12:24 PM
