Annoying Front axle clatter - JeepForum.com
post #1 of 2 Old 06-11-2012, 09:05 PM Thread Starter
TallyZJ
Since I installed Aussie lockers a few years ago my front axle always clatters very badly when I turn a slow sharp left and, while not as bad, also on sharp right turns. I have yet to figure this out. Sounds like the front axle shafts are gonna break apart and spit everything out on the ground.
It is much worse with the front drive shaft installed and a good bit less noisy when the drive shaft is out.
My only thought is to recheck the tolerances on the locker itself but I have been putting this off as I plan to swap in a high pinion D30 soon. . . . I hope.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #2 of 2 Old 11-19-2012, 08:05 PM Thread Starter
TallyZJ
UPDATE:
This clatter is due to loose/worn pinion bearings. Gonna replace that soon.
TallyZJ is offline
Removed & Reinstalled front driveshaft, now annoying vibration shudog ZJ Grand Cherokee Forum 11 12-22-2007 11:32 PM
little clatter in front end.. Jetjock16 ZJ Grand Cherokee Forum 2 01-15-2007 12:06 PM
Annoying front end noise zaq123 ZJ Grand Cherokee Forum 2 07-12-2005 12:12 PM
Front Suspenion Clatter? Stocker ZJ Grand Cherokee Forum 5 06-27-2005 09:59 AM
Front end whine ANNOYING!!! ta325 ZJ Grand Cherokee Forum 6 12-01-2004 06:47 PM
