Angry at wheel bearings which part??? - Page 3 - JeepForum.com
post #31 of 54 Old 09-10-2011, 10:17 PM Thread Starter
PolkaPower
Yea, I went around my butt to get to my elbow.
PolkaPower is online now
post #32 of 54 Old 09-11-2011, 01:03 PM Thread Starter
PolkaPower
Ok, got the new bearings in. Timkens. One says Torrington, the other KOYO both say made in U.S.A. Both come in the same Timken box.
From this pic can you tell if they are seated all the way in? I used the old bearing to start it then with the old bearing I used a piece of wood to hammer it in the rest of the way. I sure hope this was the problem. With my luck the noise will still be there and it will be the inner seals and bearings and cost a butt load of dough.
post #33 of 54 Old 09-11-2011, 04:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
torrington is the type as said, koyo is a BRAND, someone put a slightly lower grade bearing in a timken box and sold it to you for the premium...
ratmonkey is offline
post #34 of 54 Old 09-11-2011, 05:41 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Looks like you have it seated well. Squirt some gear oil in the rollers just for good measure.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #35 of 54 Old 09-11-2011, 05:52 PM Thread Starter
PolkaPower
Yea, I kinda thought that was afoot. Oh well I guess we will see if it wears out first.
I am about to take her out for the first time in a week to get some crab legs and beer. Yippie.
post #36 of 54 Old 09-11-2011, 11:43 PM Thread Starter
PolkaPower
Writing a long email to Autozone corporate with the name of the manager and location to let them know what happened. I don't expect anything. I just want to let them know that I got ripped off and won't do business with them again.
It's funny how 14 years ago when I had my 95 zj that I hated to go to A-zone. Nothing has changed.
post #37 of 54 Old 09-12-2011, 01:03 PM Thread Starter
PolkaPower
Ok well, there is still a noise there but now it's 70% quieter with the new bearings so they needed changing out. As far as the other noise goes I have narrowed it to either the carrier bearings or the brake drums. They are suspect because when I got the truck the rear brakes were worn to hell and these drums/rotors look like they have been on here for a long time. You can run your finger over them and feel a groove from years of use. The noise is low pitched and sounds like scraping not like a whining. I hope it's the drums. rotors.
Oh and thanks for all of the great advice. You guys rock.
post #38 of 54 Old 09-12-2011, 02:07 PM
bobotech
Nevermind/missed the 2nd page of posts.
bobotech is offline
post #39 of 54 Old 09-12-2011, 09:34 PM
FPKites
ZJjazzyJim
FPKites's Avatar
I suspect your rotors are scored and causing a good amount of the noise you have. I wouldn't discount carrier/pinion bearings, but they tend to take quite a bit longer to go completely out.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #40 of 54 Old 09-12-2011, 11:14 PM Thread Starter
PolkaPower
Yea, I can't see how the new brake pads can lay flat on the rotor with the grooves in it like that. I can live with that for a bit. I have a VC that's going south. I'm starting to research the 242 swap now, I don't know how much longer the vc will last. It doesn't hop to bad only when in full lock. Even then I can go really slow and it's fine. The tires are pretty worn around the edge because of it though.
post #41 of 54 Old 09-13-2011, 07:34 PM
savannahzj
Do yourself a favor and remove the front ds. My vc was going but didnt seem too bad. Well, I am now replacing front suspension parts because of the additional strain the vc puts on them. I pulled the ds about 2 months ago until I find a 242 and the time to do the swap. The other benefit is according to the overhead display I went from 14.5 mpg to 16.8.
savannahzj is offline
post #42 of 54 Old 09-13-2011, 08:51 PM
FPKites
ZJjazzyJim
FPKites's Avatar
You needed a lift anyway
Don't trust the overhead display.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #43 of 54 Old 09-13-2011, 10:02 PM Thread Starter
PolkaPower
I have a BB with bilstein 5100's on the way. I'm gonna keep it this short for a while maybe put upcountry springs in and that's it. I am not going to take the front DS out because it will grenade the 249 faster. That is very bad for the 249. The VC isn't that bad yet. I still have some time on it. I'll find a 242 with in a couple months. My front suspension needs some fixing up after 127k. I will replace parts as I go.
edit: It will not harm the TC in the later model 249 , I was mistaken.
post #44 of 54 Old 11-21-2012, 03:32 AM
zjridah
Thanks for the all the info, Autozone sold me these for my 97 D44 I'm glad I checked here before diving into it.. I would have been PISSED!! And lol wtf F.A.G. Gears? Naw man
zjridah is offline
post #45 of 54 Old 11-21-2012, 06:15 AM
96zedjay
The 5707 is a very common bearing. Not only is it used in many cars and trucks it also is used in
transmissions, transfer cases, farm tractors, combines, industrial equipment, well you get the idea.
96zedjay is offline
Carrier Bearings or Rear Wheel Bearings? StrokedWJ ZJ Grand Cherokee Forum 4 05-07-2009 01:44 PM
how do i tell if my wheel bearings are bad ksturgio ZJ Grand Cherokee Forum 6 04-21-2009 11:14 PM
Wheel bearings Mike WJUK ZJ Grand Cherokee Forum 9 08-31-2006 12:58 PM
wheel bearings Reloader77724 ZJ Grand Cherokee Forum 2 07-15-2006 01:20 PM
Wheel Bearings?? RAZZMANIAC ZJ Grand Cherokee Forum 1 03-02-2005 07:45 AM
