Angry at wheel bearings which part??? - Page 2 - JeepForum.com
post #16 of 54 Old 09-10-2011, 04:19 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
if the bearing came with a race it's the wrong one.
the zj uses only a straight roller bearing and the shaft is the inner bearing surface.
the wj uses a cup/cone tapered roller bearing.
the zj 44a uses a 5707 bearing. bearing numbers are universal as they designate the type and dimensions of the bearing.
ask for a timken 5707.
use a seal remover or screw driver to pull the remainder of that seal out and see what you're working with on the wheel bearing.
if the blind bearing puller attachment is too big to flatten out in the tube, use it. at least it's guaranteed to catch.
ratmonkey is offline
post #17 of 54 Old 09-10-2011, 04:36 PM Thread Starter
PolkaPower
Ok, it's ok if it scratches up the tube a bit? All of the bearings I looked at at all of the stores came with a race and they said they would fit. I ended up ordering them from a local drive line shop instead. The guy at the shop said they were the Dana 44 HD bearings and seals.
The 3 jaw is exactly what I need but I am stuck with what I have here as the wife and I just got into a fight and I doubt she wants to help lol.
PolkaPower is offline
post #18 of 54 Old 09-10-2011, 05:21 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
scratching the tube is a total non-issue.
timken 5707. any of the ones with races you're just paying for crap you aren't going to use.
post #19 of 54 Old 09-10-2011, 05:26 PM Thread Starter
PolkaPower
Ok here are the results. Some dents near the ridge of the seal from the larger swing puller. What is the verdict with this? Still ok to put a new one in? Or do I need to do some repairs?
post #20 of 54 Old 09-10-2011, 05:30 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i don't think those dents came from you.
slam the new bearing and race in there and run it.
never seen one blow up like that. the one i have sitting here in front of me has a seriously solid outer race compared to that tin crap. the rollers are also held in place by snap rings, not pressed over 16g metal.
post #21 of 54 Old 09-10-2011, 05:44 PM Thread Starter
PolkaPower
Yea, there was a cage and spring that held the bearings in that came flying out all over that turned my satisfaction to anger. On the race it has "Torrington" stamped into it. Well it makes me feel good that I didn't screw anything up yet.
post #22 of 54 Old 09-10-2011, 06:06 PM
FPKites
ZJjazzyJim
FPKites's Avatar
The spring is from the inside of the seal. That cage looks like poo though.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #23 of 54 Old 09-10-2011, 06:58 PM Thread Starter
PolkaPower
The pass side came out with hardly a hassle. It sounds like poop.
post #24 of 54 Old 09-10-2011, 07:10 PM Thread Starter
PolkaPower
Hahahaha I won't be buying these.
post #25 of 54 Old 09-10-2011, 07:44 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
f.a.g. bearings are very high quality. use a ton of them at work.
f.a.g., timken, skf, ntn are top bearing makers.
torrington is the type of bearing that is technically called.
post #26 of 54 Old 09-10-2011, 07:46 PM Thread Starter
PolkaPower
What about National bearings? That seems to be all that is around here unless I wait until Tuesday. I just thought the abbreviation was funny with the F.A.G. Even funnier if you are telling someone what kind of bearings you run in your rear.
post #27 of 54 Old 09-10-2011, 10:10 PM Thread Starter
PolkaPower
Just to reiterate what has been said before, the part numbers at the auto stores all are wrong for the wheel bearings for the 44a. I just looked around on Napa, Autozone, and Oreillys and just typed in 5707 and the right part came up. At the store searching under my vehicle make and year, it brought up a bearing for the dana 44hd(wrong part) and a part for the 35c which looked like the one I have. Since it said 35c I did not buy it but it is the right part. So the 5707 for the dana 35c is the part for the 44a. Makes me want to pull my hair out, such a simple thing and they got is so wrong.
Look how stupid this is. These are the correct part numbers that fit my 98 zj. Autozone even has the rear wheel bearing listed as a tranny bearing.
post #28 of 54 Old 09-10-2011, 10:48 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
IdiotZone is the worst of all the parts stores for having mistakes in the parts database.
Find a Factory Part Number Listing and you just look up and cross reference the Jeep part number.
Google Jeep J8134586 and see what comes up.
CJ7-Tim is offline
post #29 of 54 Old 09-10-2011, 10:51 PM Thread Starter
PolkaPower
Bingo http://c2c.activant.com/ctoc/index.j...JyABgMUHFUBQAA
Autocrap has the Timken bearings but not the seals. Oreilly has the National bearings but cheapo Mastercraft seals. Napa across town has both for more money. Unbelievable hassle for such a common thing.
Funny, the late night guy at Oreillys said to me that "it's the bearings that matter , not the seals". Lol what the heck is going to happen when I use cheap seals with good bearings????? I would be up the creek in 6 months doing this all again.
post #30 of 54 Old 09-10-2011, 11:08 PM
FPKites
ZJjazzyJim
FPKites's Avatar
I found that Autozone, O'Reilly and Napa think that ZJs have IRON D44s. No clue why.
When you tell them you have a D35, you get the right bearing and seal.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
Carrier Bearings or Rear Wheel Bearings? StrokedWJ ZJ Grand Cherokee Forum 4 05-07-2009 02:44 PM
how do i tell if my wheel bearings are bad ksturgio ZJ Grand Cherokee Forum 6 04-22-2009 12:14 AM
Wheel bearings Mike WJUK ZJ Grand Cherokee Forum 9 08-31-2006 01:58 PM
wheel bearings Reloader77724 ZJ Grand Cherokee Forum 2 07-15-2006 02:20 PM
Wheel Bearings?? RAZZMANIAC ZJ Grand Cherokee Forum 1 03-02-2005 08:45 AM
