Angry at wheel bearings which part??? - JeepForum.com
post #1 of 54 Old 09-10-2011, 11:50 AM Thread Starter
PolkaPower
Angry at wheel bearings which part??? No longer angry.
Every where I went today had confused employees and different looking wheel bearings than whats sitting in my axle tubes right now but they say it's the right part. WTF part do I need?
Is this the part I need??
https://www.napaonline.com/Catalog/C...RecType%3aA%29
Because it looks nothing like this below which is what is in my axle
PolkaPower is online now
post #2 of 54 Old 09-10-2011, 12:11 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Wheel Bearing - Rear Wheel - Part Number: BRG BR9
Product Line: NAPA Bearings
IMPORTANT INFO: w/ Spicer/Dana 35 Axle,w/ Spicer/Dana 44 Axle
Any of these will work/interchange.
OMIX-ADA Part # 1653622
NATIONAL Part # 5707
TIMKEN Part # NP182140904A1
SKF Part # BR9
NATIONAL Part # A10
Jeep# J8134586
CJ7-Tim is offline
post #3 of 54 Old 09-10-2011, 12:21 PM Thread Starter
PolkaPower
Ok, thank you. Now the seals. Are they the metal ring that comes with it or do they look like this?
post #4 of 54 Old 09-10-2011, 12:27 PM
CJ7-Tim
CJ7-Tim's Avatar
Bearings cages come with a matched bearing race. Install both as a matched set. Seals are seals.
www.rockauto.com has the best info and best selection of parts. Once you locate your part, click on the INFO tab for each available part, some manufacturers have additional info, specifications, and cross reference numbers.
Google for a JEEP Factory Part Number Listing. They show Jeep factory part numbers for every part on your Jeep.
Most parts store counter monkeys are morons and can only tell you what the computer screen says. The computer parts data bases have numerous proven errors.
You should always know more than the parts monkeys about what parts you need, before you enter the store.
CJ7-Tim is offline
post #5 of 54 Old 09-10-2011, 12:36 PM Thread Starter
PolkaPower
Thanks, that is the exact reason that I have not bought anything yet. I will print out these parts and take them with me. Hopefully I will have this back together by the end of the day and have no more noise!
Thank's Tim
post #6 of 54 Old 09-10-2011, 12:43 PM Thread Starter
PolkaPower
So to clarify, I will not need the race according to this pic
post #7 of 54 Old 09-10-2011, 12:59 PM Thread Starter
PolkaPower
Ok, so the ZJ uses the C clips and doesn't use the retainer rings. The WJ has the bearing pressed onto the axle shaft with the retainer rings but they come with the bearing which was confusing me.
post #8 of 54 Old 09-10-2011, 01:07 PM
CJ7-Tim
CJ7-Tim's Avatar
If your bearing comes with a new race, you need to use it. You can't mix new and old bearing parts.
CJ7-Tim is offline
post #9 of 54 Old 09-10-2011, 01:36 PM Thread Starter
PolkaPower
Ok will do. I am giving this thing hell with the slide hammer and it's coming slowly but it's in there good.
post #10 of 54 Old 09-10-2011, 01:58 PM Thread Starter
PolkaPower
I ran into a pretty big snag. I don't think that I have the correct size bearing removal adapter. They gave me a kit with 1 1/2 to big
1 3/4 to big
1 1/4 to small
It pulled the seal and part of the bearing case came off and all the bearings fell out but the case or ring is still stuck in the tube. I tried to attach it again but the 1 /14 just slips off and comes right out with out the bearing ring.
I guess my next question is how to get out the remaining part without damaging the tube.
post #11 of 54 Old 09-10-2011, 02:27 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Wow...never seen the collar shatter like that.
Dremel?
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #12 of 54 Old 09-10-2011, 02:30 PM Thread Starter
PolkaPower
I have one but I am very hesitant to use it. I probably don't have much choice at this point though. I have tried to re attach the puller 3 times and it just slips right off. I am worried that this will happen to the other side too.
post #13 of 54 Old 09-10-2011, 02:59 PM
jnicewan
Just be very careful with a dremel, most of the time you only need to go about half-way through that outer shell and when you put the slide hammer back on the shell it might break it and come out ( make sense?)
If you do get into the axle tube, its not that big of a deal if its only a little bit.
jnicewan is offline
post #14 of 54 Old 09-10-2011, 03:08 PM Thread Starter
PolkaPower
I hear you on that. I was looking at the swivel end of the puller and it looks like it is just a tiny bit to small to catch the lip of the bearing and slips right off. That's how it caught onto the bearings themselves and ripped the outer lip off. I can pull it out without the hammer attached. What a pos. I guess it can never be too simple. I am guessing that I can expect this with the other side as well.
post #15 of 54 Old 09-10-2011, 03:17 PM
FPKites
ZJjazzyJim
FPKites's Avatar
I'd go with a 3-jaw on the other side. Don't use the washer looking attachment.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
Carrier Bearings or Rear Wheel Bearings? StrokedWJ ZJ Grand Cherokee Forum 4 05-07-2009 01:44 PM
how do i tell if my wheel bearings are bad ksturgio ZJ Grand Cherokee Forum 6 04-21-2009 11:14 PM
Wheel bearings Mike WJUK ZJ Grand Cherokee Forum 9 08-31-2006 12:58 PM
wheel bearings Reloader77724 ZJ Grand Cherokee Forum 2 07-15-2006 01:20 PM
Wheel Bearings?? RAZZMANIAC ZJ Grand Cherokee Forum 1 03-02-2005 07:45 AM
