Ambient temperature sensor not working - JeepForum.com
post #1 of 8 Old 09-04-2012, 11:02 AM Thread Starter
Bale
The overhead display always shows 0 degrees.
Any tips on what the problem might be? Broken signal wire? Dead sensor?
How can you troubleshoot and fix it?
1998 ZG (ZJ) Grand Cherokee Ltd, 4L 4x4
Bale is offline
post #2 of 8 Old 09-04-2012, 02:56 PM
jaguarjoe
On my '95, the sensing thermistor is in front of the radiator near the bottom. It goes to terminals 9 & 10 on the OH console. The wires are Dk Grn/Red (9) and Lt Grn/Wht (10).
A thermistor changes resistance with temperature. Cold = high ohms, Hot = low ohms. If you put an ohmeter across the sensor and heat and/or cool it you'll see the resistance vary. If it is 0 ohms or infinite ohms, the sensor is faulty. Thermistors come in hundreds of values, I do not know what the sensor value is supposed to be. Go to the P n P and buy one for 50 cents.
If you go to Radio Shack and buy a ~50,000 ohm potentiometer, You can feed that into the console with the sensor unplugged. Turn the pot and see the readout change. If it doesn't change, the console is faulty.
Hope this helps
Once I thought that drinking beer was bad so I just stopped thinking
jaguarjoe is offline
post #3 of 8 Old 09-04-2012, 05:31 PM
AVR2
You can try doing the overhead console self-test: hold down the two buttons under the display and then turn the ignition on. Continue to hold the buttons down until all the segments in the display light up. The display module is now performing its diagnostics and will do one of three things: if everything is OK it will return to normal operation; if its internal circuitry is faulty it will display "FAIL", and if it is not receiving all the CCD messages it needs (which can include the temperature data) it will display "CCD".
The resistance for the sensor should be between 2k and 350k.
AVR2 is offline
post #4 of 8 Old 09-04-2012, 06:59 PM
jaguarjoe
That means almost any or every thermistor will work. Kinda hard to believe it would especially constrained by the <12v system inside of the console.
post #5 of 8 Old 09-04-2012, 07:01 PM
AVR2
Those are the resistance figures to look for according to the factory service manual.
AVR2 is offline
post #6 of 8 Old 09-05-2012, 12:20 AM Thread Starter
Bale
Thanks!
Bale is offline
post #7 of 8 Old 09-05-2012, 01:21 AM
moggie99
New sensors are very cheap online - I bought one from Rockauto and the current price is just over $16.
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #8 of 8 Old 09-05-2012, 02:10 AM
jaguarjoe
THIS is cheap:
http://www.allelectronics.com/make-a...RMISTOR/1.html
Ambient Temperature Sensor bootleg420 ZJ Grand Cherokee Forum 2 04-14-2015 07:17 PM
Ambient Temp Sensor? jam66 WK Grand Cherokee & XK Commander Forum 2 11-09-2010 08:46 AM
Ambient Air Temperature Wiring hamuel2003 ZJ Grand Cherokee Forum 1 12-02-2009 07:02 PM
Ambient Temperature Sensor Question? IdahoZJGuy ZJ Grand Cherokee Forum 5 07-10-2007 08:44 AM
'96 GC Ambient Temperature Sensor wheelytyred ZJ Grand Cherokee Forum 3 11-16-2004 01:12 PM
