alternator wont keep charge - JeepForum.com
post #1 of 14 Old 10-30-2012, 10:03 AM Thread Starter
semipro06
1993 XJ Cherokee
ok for some reason and i ahve switched two alternators in the last month. as im driving down the road. when im stopped at a red light or a drive thru my jeep all of a suddden it stutters hard and trys to die and the charge guage inside moves up and down. what could cause this i have disconnected all my extra wiring and custom work. and still does it. this is all started after one of my coworkers and i had noticed i had an oil leak and we couldnt find it so he had me power wash it and i thought he what he was talking bout but fail to tell me to covor my alternator when i did it. but now there is a new one in it and its still doing it. what could be the cause?
semipro06 is offline
post #2 of 14 Old 10-30-2012, 10:11 AM
Donnyd21
Ecu
Donnyd21 is offline
post #3 of 14 Old 10-30-2012, 10:50 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I've washed many alternators.
Have the battery and alternator checked at your local parts stores. I'd they're good then it's the engine computer.
ratmonkey is offline
post #4 of 14 Old 10-30-2012, 10:51 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Check all battery wiring too... But it's usually the computer with voltege going crazy
post #5 of 14 Old 10-30-2012, 10:56 AM Thread Starter
semipro06
1993 XJ Cherokee
So would check it its 93 AutoZone said it doesn't have a plug to where they can check it on the computer
post #6 of 14 Old 10-30-2012, 01:23 PM
Oldfrog
2007 WK
Dont let an autozone employee TOUCH the PCM.
No way to check it, anyway. It's either good or it's not.
I have gotten two bad alternators in a row before. Check the alternator and battery, then the connections. If it still isnt charging, it's the PCM.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #7 of 14 Old 10-30-2012, 02:40 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
not the ecu, the alternator...
post #8 of 14 Old 10-30-2012, 05:50 PM
ozzy_2_me
1994 ZJ
dido
ozzy_2_me is offline
post #9 of 14 Old 10-30-2012, 06:26 PM
Foundrydude
If idle drops like the vehicle is about to die, the volt gauge should move a volt or two. That's normal when the engine is stumbling because the alternator won't charge much at 250 engine RPM.
Foundrydude is offline
post #10 of 14 Old 11-12-2013, 05:15 PM
blackjack12982
1994 ZJ
OK, bringing this back to the top...
94 ZJ w/ a 5.2L. Rebuilt alternator will not charge on the vehicle, but bench tested at O'Reilly's and it tests good. Two different working PCM's don't change anything. Battery is fully charged, but will discharge slowly while engine is idling. Anyone have any new ideas?
blackjack12982 is offline
post #11 of 14 Old 11-12-2013, 07:12 PM
rlcii77
Be sure the belt is not slipping on the alt. pulley... Is it the correct pulley on the alt.? I ask because I thought I read or heard something about different sized pulleys causing an issue with either an alt. or power steering pump, can't quite remember for certain... Double check all the wiring and maybe the fuses... Good luck...
'94 Limited ZJ (CRUSHED, kept the 5.2L, 46RH & 249 TC)
'96 Orvis ZJ
'98 Slate 5.9 ZJ (DD)
rlcii77 is online now
post #12 of 14 Old 11-12-2013, 07:30 PM
Gearhead31
were the cables checked? heavy corrosion would slap down the voltage traveling through. Lower voltages(low rpm idle) wouldn't wanna pass through but higher voltages(fast driving/highway driving rpms) would pump enough power to overcome the corrosion. Ya never know, sometimes the simple questions are the best ones
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #13 of 14 Old 11-12-2013, 08:03 PM
Scopez
1994 ZJ
Ever since I did bigger grounds, my ZJ runs so much better at idle. I use to not be able to run my air at idle, it'd kill my battery gauge. Now I have no issue.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #14 of 14 Old 11-13-2013, 01:38 AM
Oldfrog
2007 WK
Check the alternator grounding point on the bracket. Then plan on replacing the battery cables, and checking the PDC connections. That's where I'd look.....if I didnt want to use a voltmeter to check voltage drop at different points.. ( which I would do)
Oldfrog is offline
alternator issue , electrical , electrical problem , power loss
