Alternator Amps, how could you tel? - JeepForum.com
post #1 of 11 Old 06-25-2009, 02:13 PM Thread Starter
Hamid
2015 WK
After installing a Taurs 2 speed fan in my 93 ZJ 4.0L, I thought it will be better to throw in a 136 amps alternator to help in compensating for current draw and keep enough voltages to other sys.
I did not see any changes in current boost, just like the old 90amps alt is still there, sometimes needl goes to near 9 volts when I switvhed to the high speed.
I just want to know how do I measure the alt in order to see if its 136 amps, or 90 amps.
Thanks for your advise.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #2 of 11 Old 06-25-2009, 04:55 PM
81cjkid
1981 CJ7
I don't know what tools you have access to, but if you use an amp meter (the clamp type),and a battery tester you can find out. Take the amp tester and put it on the negative battery cable, then take the battery tester and put a load on the battery. You will then be able to see how many amps your alternator is kicking out, or if its working correctly.
81cjkid is offline
post #3 of 11 Old 06-26-2009, 06:58 AM
Marcos
Where did you get the new alternator? The 136a alternator is physically larger int he main body than the 90a. The mounting and connections are the same, though.
Unless you bought a re-wound aftermarket one, then it could be different.
Marcos is offline
post #4 of 11 Old 06-26-2009, 08:45 PM Thread Starter
Hamid
2015 WK
81cjkid: I know th the battery tester, but what is an amp meter, can I use the digital ohmmeter instead.
Marcos: It looks the same as the old one,
Thank you all for the info.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #5 of 11 Old 06-26-2009, 09:22 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Marcos is correct, the 136A ND from a V8 ZJ/WJ/Durango is physically larger than the 90A ND, and if you're replacing the 90A with the 136A unit, you'd have had to grind into the mounting by about 1/4" to clear the larger frame. So, chances are you still have the 90A.
It should also be borne in mind that the alternator cannot generate maximum output potential until the spindle speed is up around 3300-3500rpm - which comes out to about 1000-1200rpm at the crankshaft. If you're checking at idle, it's not a valid test. (i.e. - my 195A Delco CS-130 can only generate some 70A at idle. Period. At 1200rpm, it can generate 198A - solid!)
NB: The current function on the typical DMM (that you'd buy at the hardware store or parts house) is only good for about 10A before you blow the fuse. The "lobster claw" type - that clamps around the wire and reads from the magnetic field the current generates - can be good for up around 500A depending on the model. If you look at one, make sure it reads DC Amps (since AC and DC amps generate different magnetic fields, trying to read a DC field with an AC ammeter will confuse the meter and give you an invalid reading. And vice versa.)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #6 of 11 Old 06-26-2009, 10:54 PM
Some_Anchovies
If I would have gotten a new higher amp alternator, I would have gone with a high output one... (like atleast 200 amps). But that's just me.
Sounds like you got ripped off with another 90A
Some_Anchovies is offline
post #7 of 11 Old 07-02-2009, 05:55 AM Thread Starter
Hamid
2015 WK
I think we went off the track, my main Q was how to measure the Alt AMPs???
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #8 of 11 Old 07-02-2009, 06:31 AM
vansskaterfreek
with an amp meter....
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #9 of 11 Old 07-04-2009, 04:22 AM Thread Starter
Hamid
2015 WK
fine, but how do you connect it?.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
post #10 of 11 Old 07-04-2009, 10:21 AM
ZeeJay1997
Unless you have a clamp on DC ampmeter, take it to autozone or AAP and they can check it out.
ZeeJay1997 is offline
post #11 of 11 Old 07-05-2009, 01:37 AM Thread Starter
Hamid
2015 WK
No autozone around here, I have to do that by myself, Thanks Zeejay1997.
2015 GC Laredo 3.6L
2500 Miles
Hamid is offline
Stock Alterntor Amps ALombardi WK Grand Cherokee & XK Commander Forum 2 01-24-2010 03:12 PM
can you have 2 factory amps? grand95zj ZJ Grand Cherokee Forum 9 11-21-2009 10:34 AM
40 Amps ASD fuse keep blowing Hamid ZJ Grand Cherokee Forum 1 11-13-2009 11:54 AM
Stereo Q: Where did you mounts your amps Laid-Off ZJ Grand Cherokee Forum 5 07-01-2008 07:43 PM
Infinity Amp with New Amps... Wiring Question ugmoe2000 ZJ Grand Cherokee Forum 3 08-29-2004 10:41 AM
