altenator question - JeepForum.com
post #1 of 3 Old 06-16-2003, 09:19 PM Thread Starter
f14x4
altenator question
i have a 96 4.o and i think the stock altenator is 117 amp.
i have one optima yellow top and i want to put in a second for the stereo since i have alot of lights comin my way...i will have an isolator so the second battery will only charge when the vhicle is running and will not discharge when it is off...will this altenator be enough temporarily like for the summer or will i need a bigger one right away? also do the limiteds have bigger altenators cause i dont want to pay alot of money for a stinger.
my other option is there is place by me that till rewind my altenator but im not sure how expensive it will be...im guessing no more than 200, so if thats the case what should i rewind it to? i think the batterys are 600 cold crankin amps but like 85 continious or somtihing, so should i do double the batterys like 190 amp altenator or what? there was a guy that i met through ebay that had 160 amp altenators that weere chargin 85 amps at idle but i lost his addy. should i just go to the place and tell them thats what i want ? my main battery has all stock power, plus a h.i.d. (real conversion) kit for headlights, plus im planning on at least 4 pairs of drivving lamps about 85 watts. and a pair of loading lights as well as secondary reverse lights, at about 55 watts. so the most i can do i s 4 pairs of driving lamps, the hid's and the stereo blasting all at once, but the second battery is strictly for the stero.
any info will be helpful
thanx in advance
(0IIIII0)
THERES ONLY ONE
f14x4 is offline
post #2 of 3 Old 06-17-2003, 04:44 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Hey,
post this question over at JU under the stereo part. Those guys are wizards with amps and batteries.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 3 Old 06-17-2003, 06:08 AM
ALS59LTD
ALS59LTD's Avatar
the limited with heated seats has a bigger alternator. 150amp? not sure on the number but it's bigger.
-Alex
http://www.jeepforum.com/forum/f22/turbocharged-2-4l-jeep-tj-me-too-2255329/
ALS59LTD is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 ZJ Grand Cherokee Forum 2 03-23-2011 01:59 PM
Code 41 , altenator for sure ? newfieZJ ZJ Grand Cherokee Forum 17 01-16-2010 10:12 AM
Radio code question - option question... GARover WK Grand Cherokee & XK Commander Forum 5 12-25-2009 10:39 PM
air condition face unit question n00b question Fatsooo ZJ Grand Cherokee Forum 4 09-21-2008 08:45 PM
couple minor questions. door question and mirror question Irish_Assassin ZJ Grand Cherokee Forum 2 07-04-2008 02:14 PM
