Alt volt regulator.......hmmmm - JeepForum.com
post #1 of 4 Old 10-25-2009, 10:31 AM Thread Starter
NewhampshireYJ
So iv been having this charging problem with my GC.Ran all new cables,battery,etc. Still didnt do the job.
So i brought the alt to get tested and they said its all good except the regulator on it is failing....to many/to less of v's going out.... He told me the black back is the volt regulator.
2 bolts and a phillips and go to jeep stealership and get a new one/install it.
My question is can u even get a v regulator for the alt?
If so were at besides stealership?
Or just get a new alt?
1993 Black YJ
All Terrain 33's-4 inch RC lift
Revolver shackles- some other stuff
NewhampshireYJ is offline
post #2 of 4 Old 10-25-2009, 10:42 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Not sure what's inside that little black box. The FSM diagrams ignore it. Its not the regulator. The two small posts connect to the field coil inside the alt, which the PCM uses to regulate the system voltage. I'd try another alt at this point. If it still won't regulate, it could be PCM or wiring.
HighLonesome is offline
post #3 of 4 Old 10-25-2009, 05:57 PM
platinum5.9
2003 WJ
yeah the regulator is built into the computer on these
platinum5.9 is offline
post #4 of 4 Old 10-25-2009, 06:20 PM
ZeeJay1997
The brushes are easy to change. Go to local alternator shop and ask for a brush pack for whatever brand you have. 10-15 bucks.
But it could be a diode or capacitor too... not to mention bearings...
ZeeJay1997 is offline
No start - only get 6 volt to starter LWBII00 ZJ Grand Cherokee Forum 19 01-07-2010 07:21 PM
Hmmmm, Interesting problem.... fscott4 ZJ Grand Cherokee Forum 4 05-29-2009 06:14 AM
TPS sensor readings volt/ohm speedbullet2 ZJ Grand Cherokee Forum 3 03-30-2008 11:11 AM
Volt Gauge at Max, Maybe not the Guage? Jon08JK ZJ Grand Cherokee Forum 7 12-10-2007 10:49 AM
Battery Volt Gauge UnDeR EsTiMaTeD ZJ Grand Cherokee Forum 3 12-16-2005 02:17 PM
