Quantcast Almost normal...we will see. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Almost normal...we will see.
Old 03-22-2009, 03:10 PM   #1
nashmd454
In an effort to track down the mpg grimlan I have so far to date done these mods/adjustments. I replaced the rear end due to it about to explode...bought new tires..if you recall I bought some Perelli Scorpiona ATR'S and the weighed 43lbs and now I have BFG T/A and they are 29lbs. Now today I flushed the engine and (should I say that I put oil back in or can we assume that) changed the sparrk plugs and dropped the tranny pan and changed the filter and flushed it as well (man that stuff is messy). I had a magnet installed in the pan and it was fairly clean yet showed some darkness (metal). Then to top it off I replaced the ECU to the stock one and see if that will help. If I still continue to get 10.5 (I was at 9.1 when the rear end was done) then a friend will hook up some computer and read my injectors and such. Oh...I also have fixed the o2 sensor problem as well.
Other suggestions will be appreciated.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote
Old 03-22-2009, 03:40 PM   #2
SoCalDevyn
in the 10mpg area is what i get most of time too, though i know my steel rims and heavy tires dont help at all i thought about getting a new CAT and new o2 sensor
98 ZJ Limited 5.2, Blacked Out, 5.5" lift made with IRO coils and ACOS, 15x8 Pro Comp 97's, 33x12.5 General Grabbers, Custom Front Bumper, Rusty's Disco's, KOR Light Bar, 8000K HID's, Magnaflow, PA, CB, 5% Tint, System, TJ Gas Bezel, JKS Rear Trac Bar, Rusty's Front Trac Bar, KOR Stabilizer, Airaid, Hella 700's w/HID's, E-Fan, RCX Diff Guard, Clayton Brake Lines, Iron Man Extreme Control Arms, MSD, Gen Right Louvers, Custom Sliders, IRO Belly Skid
SoCalDevyn is offline   Reply With Quote
Old 03-22-2009, 04:01 PM   #3
j_dennis13
air filter?
j_dennis13 is offline   Reply With Quote
Old 03-22-2009, 05:47 PM   #4
dougy147
2008 WK
I know with the 4.7 I can get up to 20 or so, but I can also be in the low teens sometimes. Seems to happen when it's nice out and the windows are down, sunroof open, music blasting
Seems for some reason, I have gotten a few speeding tickets in the past under similar circumstances...
Maybe you should try the brick mod. You get a brick, and put it behind your gas pedal so you can only push it down about 1/2 way....I've heard this works wonders for mileage
Seriously though, driving style can have a lot to do with it. If you only drive around town with little to no highway driving and are a little heavy on the gas you're probably not going to do much better.
The Past
95 ZJ Laredo 4.0
00 WJ Laredo 4.0 & 4.7
The Present
08 WK Laredo 4.7
07 JK Unlimited Sahara
dougy147 is offline   Reply With Quote
Old 03-22-2009, 06:15 PM   #5
nashmd454
when I got the rear end done there was a break in period where I had to go easy....since then and still I do not hit the gas like I used to....typically I never go above the 2k mark on the tach.
Old 03-23-2009, 08:43 PM   #6
nashmd454
I figured I would update this...I just noticed today that at times when I start and stop (short distances) and rarely on normal startup I have noticed some blue smoke from the exhaust and then it clears. Very little mind you. One time I swore I saw blue when I took off...but never again.
Old 03-24-2009, 11:43 AM   #7
coupleofjeeps
2k on the tac is pretty low. i cant see how that would be much of it ?
coupleofjeeps is offline   Reply With Quote
Old 03-24-2009, 12:37 PM   #8
nashmd454
yeah....most around here who know me are surprised I drive so civil...but still bad mileage. Hoping it is just a winter thing and it will get better. Then again...why isn't all the jeeps having the same prob.
Glock Forum
