All Power Windows Don't Work?????? - JeepForum.com
post #1 of 14 Old 12-16-2003, 04:57 PM Thread Starter
Clay454
I have a 1995 Grand Cherokee Orvis. All four power windows have stopped working. No Up! No Down. Checked fuses, checked the controll cluster.
I have seen this problem all over the internet, but nobody seems to know what the problem is.
Anybody in here have any clues?
Rg3ecom@aol.com
Clay454
Clay454 is offline
post #2 of 14 Old 12-16-2003, 05:33 PM
Stocker
Welcome to the boards!
Take a look at the wiring harness connector in the driver's door jamb. Pull back the rubber boot and look for broken wires or corroded connections. Common problem area. Also make sure the torx screw that holds the connector together is snug. Good luck!
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #3 of 14 Old 12-17-2003, 04:27 PM Thread Starter
Clay454
Thanks Stocker...
There are two completely cut wires and two shredding wires inside the boot.
I will let you know how it turns out when I splice it all back together this weekend!
Peace
Clay
Clay454 is offline
post #4 of 14 Old 12-17-2003, 07:13 PM
Stocker
Stocker
Stocker is offline
post #5 of 14 Old 12-20-2003, 09:04 AM Thread Starter
Clay454
Thanks! I have power windows again.
A black wire and a red wire ironically were completely broken.
Although it was 30 degrees outside, it only took a grueling seven minutes to fix!
Thanks Again!
Clay454
Clay454 is offline
post #6 of 14 Old 12-26-2003, 11:46 AM
unreal33
I'm having the same problem w/ my 93 ZJ.. my fuse are good, but my wires are also not cut.. there are two wires how ever that are split but still connected I believe a black wire w/ white stripe and a red wire w/ a black stripe.. could my driver side switch be gone?
* also oddly enough I do have one solid black wire (coming from the door) thats been cut.. but there isn't another wire on the oposite side to meet up w/ it.. think this is related?
unreal33 is offline
post #7 of 14 Old 12-26-2003, 12:13 PM Thread Starter
Clay454
Pardon the expression, but my problem seemed pretty clear cut.
I would bet that the black wire is a ground. You may get partial power even if this wire is cut.
I had to cut back the black rubber boot between the door and the door-jam to get to the cut wires. It's pretty tight, but I would go ahead and splice everything back together and see what happens.
Let me know how it goes!
Peace!
Clay454
Clay454 is offline
post #8 of 14 Old 12-26-2003, 12:35 PM
unreal33
well what am I splicing the black wire to? there isn't any thing else in there to conect it to! lol
unreal33 is offline
post #9 of 14 Old 12-26-2003, 01:31 PM
Aryding
Power Windows in Rear not working
My '93 also is having a problem such as yours, but the funny thing is that I tested the connection and its good. So now I have no idea what to do
Aryding is offline
post #10 of 14 Old 12-26-2003, 03:48 PM
Swamp Boy
Swamp Boy's Avatar
Check the power in the drivers switches and if you have power there take off the passenger door skin and check there..
IF you dont have power there then follow the wires till you find the short..
BUt start in the drivers door ( door jamb is the usual culprit..)
Pull on each wire individually ..(this may take some time.) Dont pull hard just hard enough to tell if the wire is broken but still inside the rubber coating.. Opening and closing of the door could have broken a wire...
Oh yeah.. Dont want to forget ... Welcome to the board..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #11 of 14 Old 12-27-2003, 02:50 PM
Aryding
Stupid Back Windows
Well it looks like from the drivers side I can put up the front windows but not the back ones. I can also lock all the doors. I found that by checking the connections the back doors were getting their 12 volts, so I'm pretty sure there is no cut wires. the only BUTTONS that don't work are the back doors and the drivers side for the back door windows. But the thing is is that the connection is getting its 12 volts. I have no idea now what to do so any tips would be nice, the car goes outside in the pouring rain in a couple days.
Aryding is offline
post #12 of 14 Old 12-27-2003, 04:51 PM
Aryding
Well now I notice that locking the doors can only happen when the car is not on "acc" but when it is it only unlocks. Maybe if I start up the car the when I get it all back together I'll be able to put the windows up... ;(
Aryding is offline
post #13 of 14 Old 12-30-2003, 08:32 PM
Aryding
Well I got them up just in time, I jumped the back doors and they went up!!! So now I'm pretty sure it's the switchs that are faulty and I'm going to call Jeep tomorrow and by some new ones.
Aryding is offline
post #14 of 14 Old 12-31-2003, 04:15 AM
Meerkat
Before spending money on new switches, have you tried taking them apart and cleaning the contacts? Momentary contacts like these often make a spark that will scorch the contact surface. Disassembly and a little bit of emery cloth will fix 'em right up.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
Power windows don't work speedluvn ZJ Grand Cherokee Forum 3 02-17-2009 07:05 PM
power windows work when zj is off kidA ZJ Grand Cherokee Forum 4 02-05-2009 07:42 PM
Power windows don't work nomo85 ZJ Grand Cherokee Forum 1 05-10-2008 08:29 PM
Power Windows won't work. 94 zj limited ZJ Grand Cherokee Forum 1 11-27-2006 03:10 AM
Power windows work....sometimes 93DDQZJ ZJ Grand Cherokee Forum 6 07-14-2006 10:39 PM
