alignment problem? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > alignment problem?
Huge Soft top SaleRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits BLACK FRIDAY SPECIALS!! You asked, we deliver!
Unread 09-16-2012, 06:33 PM   #1
liftedzj1994
1994 ZJ
alignment problem?
i put my zj on the road this weekend for the first time in 6 months and noticed that to get the jeep to go straight that the wheel had to be cut to the right like an 1/8-1/4 turn. how do i fix this
liftedzj1994 is offline   Reply With Quote Quick reply to this message
Unread 09-16-2012, 10:08 PM   #2
phitmein
phitmein's Avatar
did you checked the air pressure in the tires ?
If that's not it, it could be flat spots on the tires if it wasn't doing it before.
It could be a brake dragging just a bit from sitting up.
Was it fine before ?
Phit
phitmein is offline   Reply With Quote Quick reply to this message
Unread 09-16-2012, 11:32 PM   #3
KoreaZJ
1994 ZJ
If it's not pulling to the side and the wheel is just off-center... adjust the drag link to center the wheel.
If any front end components are badly worn, replace those first.
If it pulls to the side, might need an alignment.
KoreaZJ is offline   Reply With Quote Quick reply to this message
