Alarm won't stop. Help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Alarm won't stop. Help!
Bead Lock Wheels! Raceline, Trail Ready, & Trail-GearTJ Dana 60 - BOLT IN REARRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 12-29-2010, 07:17 PM   #1
5point9Limited
I lost my key fob so I have no remote. I locked my doors from the power door lock switch then shut the door. I left something inside, so I unlocked it and opened the door before the Jeep could fully arm itself.
The horn started beeping and the lights blinking. I turned the key in the ignition, and it starts but shuts right off and continues beeping and flashing. I disconnected the positive cable because it was a little loose and I could muscle it off.
Will this reset it? or is there a secret to this "hi-tech alarm"?
5.9 ZJ
Thanks all.
Goodyear MT/R 245-75-16, Mopar PCM ECU, 52mm APS Throttle Body AND spacer, Flowmaster Exhaust, Homebrew K&N Intake, Summit 3" exhaust cutout, OME steering stabilizer, 2.25" B. Boost, ProComp MX-6 adjustable shocks,
Up-Country springs.
5point9Limited is offline   Reply With Quote
Unread 12-29-2010, 07:48 PM   #2
94chb
unlock the door with the key. try drivers door or passenger door if that dont work unlock hatch with key, alarm will turn off, while everything is hooked up
94chb is offline   Reply With Quote
Unread 12-29-2010, 07:55 PM   #3
Nick_Knipp
1986 MJ Comanche
ahh yeah i love the alarms in the ZJ, i had a friend drive around the block then i hit the panic button, Jeep blared the alarm and stalled, man he was freaking out
i just held the panic button for a few secs and it shuts right off. if that dont work you got a mad Jeep, just disconnect battery
"Jeeps don't break, Dumb asses break 'em"
Nick Knipp, 2010
'86 MJ XLS 4x4 2.8L 3spd longbed buckets
'12 MK Sport 2.4L AT rescue green
Nick_Knipp is offline   Reply With Quote
Unread 12-29-2010, 08:29 PM   #4
ZJ_This
Love the fact im not the only one this has happened to, lol. Guy i bought the jeep off of never told me about the alarm or how to disarm it without the remote. Was a fun time waiting on the alarm to stop. My disarm only works using the key in the passenger side door.
ZJ_This is offline   Reply With Quote
Unread 12-29-2010, 09:26 PM   #5
94chb
i learned when i locked my keys in the jeep and tried to open it and the alarm went off, i had to get a cop to come unlock it for me, i was in a walmart parking lot
Unread 12-29-2010, 10:00 PM   #6
Erki
1994 ZJ
mine has to be unlocked with the key in the passenger door.
Erki is offline   Reply With Quote
Unread 12-29-2010, 10:02 PM   #7
ABQ-TJ
I got fed up with that crappy "alarm" and pulled the module from behind the glove box.
[SIZE="4"][URL="http://www.nmoffroad.com/forumvb/content/"]New Mexico Offroad[/URL][/SIZE]
[SIZE="4"][URL="http://www.jeepforum.com/forum/f22/abqtjs-2000-tj-build-1310472/"]My Jeep Build[/URL][/SIZE]
[SIZE="4"][URL="https://www.facebook.com/NMOffroad"]NMOffroad Facebook[/URL][/SIZE]
ABQ-TJ is online now   Reply With Quote
Unread 12-30-2010, 02:18 AM   #8
5point9Limited
Thanks boys. I'll let you all know what happens in the am!
Up-Country springs.
Unread 12-30-2010, 03:47 PM   #9
SomeGomer
A GC I had a couple years back did that. Whenever it was unlocked with the key in either door it would go off and I would have to lock and unlock it with the passenger door over and over. I ended up just not locking it.
SomeGomer is offline   Reply With Quote
Unread 12-30-2010, 04:34 PM   #10
jw100990
Mines broken too and the only way to make the alarm go off is to unlock the rear hatch first then unlock your door...disconnecting the battery does nothing cuz when u connect it again the alarm still goes off and then u gotta set ur clock and all thay again...Thats how mine is atleast
jw100990 is offline   Reply With Quote
Unread 05-21-2012, 01:49 AM   #11
jeepforum
Same problem and fixed now. The key wouldn't reset the alarm in my 93 grand cherokee because the reset switch fell off the back of the key tumbler. Found this out by taking off the door panel and seeing the two wire switch not connected. This one has a small triangle hole that slides on the back of tumbler. There was a dot above one flat (of triangle), so I put that to the top. Pushed the switch back onto the end of tumbler where the small triangle shaft sticks out. Then, I mixed up a small amount of JB weld (epoxy) and put a small dab on the top of it so it wouldn't fall off again. (that was done after testing it)
Hope this helps.
jeepforum is offline   Reply With Quote
