alarm system on 97 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > alarm system on 97
DIY tube fender kitsAmsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 07-04-2012, 01:50 PM   #1
grghunter4
alarm system on 97
Alarm goes off when using key to unlock doors..... how to fix or disconnect
grghunter4 is offline   Reply With Quote
Unread 07-04-2012, 04:10 PM   #2
gunner44
Fill out the Jeep info in the profile, American jeep, right? "The vehicle immobilizer system is factory-installed standard equipment on models built for sale outside North America. The vehicle immobilizer
system can only be disarmed using the Remote Keyless Entry (RKE) transmitters." You looked in the Owners manual. If you have the VTSS system the key should disarm used in either front doors. Both being out is unusual, The Body Control Module BCM is involved next.
gunner44 is offline   Reply With Quote
Unread 07-04-2012, 06:21 PM   #3
grghunter4
It works via the keyless entry.. but we only have one key less entry if it was to become lost then we can no longer unlock doors and its a pain having batterys go out on keyless entry and not be able to unlock doors till batterys are replaced
Unread 07-04-2012, 07:09 PM   #4
JasonStebbins
If you want to disconnect/disable the alarm, do this.
http://www.jeepforum.com/forum/f13/h...our-zj-483020/
JasonStebbins is offline   Reply With Quote
Unread 07-04-2012, 08:00 PM   #5
Pugulis
If the alarm doesn't disarm after unlocking the door drivers door, try unlocking the passenger door or the rear hatch. Either one of those should do the trick. Also, If you lock the doors while the key is still in the on position, it won't arm the alarm.
[_][]☺[][][]☺[][_] 96' Grand Cherokee Laredo 265,000 miles and still going strong.
Pugulis is offline   Reply With Quote
Unread 07-04-2012, 08:31 PM   #6
KoreaZJ
1994 ZJ
Keep your alarm, buy another remote from e-bay
KoreaZJ is offline   Reply With Quote
Unread 07-05-2012, 09:34 PM   #7
grghunter4
By dissarm i mean get rid of alarm not turn off for the time being... its pointless any how i got relay taken out so it dont sound. Because ill caught my self opening the one door that dont lock to lock it manually after activating alarm and it goes off scaring me
Unread 07-05-2012, 09:49 PM   #8
spidermonkey
I gave up trying to fix mine, I just don't arm it. I have no fobs. I let everyone else out of the Jeep, (if there is passengers), hit the power locks, open the driver's door and lock the drivers door manually. No alarm issues at all, it never gets set. Do NOT do the purple wire crap on a 96-98, it will not work. If someone got it to work I want proof. It's either that or find the faulty part and replace it.
98ZJ, 4.0,242, 8.8 Detroit, hp30, 4" lift, IRO LA's 4.56's, 33" Firestone MT's, custom rear bumper, ARB front, Engo E9000, factory skids
My driveway build here: http://www.jeepforum.com/forum/f197/spidermonkeys-98-zj-build-716209/
speedo reading x spd gear tooth count/gps speed = new spd gear for dead on accuracy
North Shore Wheelers www.nsw4x4.com
spidermonkey is offline   Reply With Quote
Unread 07-05-2012, 10:00 PM   #9
grghunter4
Shot so the wire thing wont work on my 97... and its not clear on what side gets grounded out
Unread 07-06-2012, 07:03 AM   #10
gunner44
Look out for this, My horns were not working, mice, Went to the store, locked my doors with switch through habit, this time with the window down. Came back, reached in and unlocked the door. Jeep would not start, checked my usual stuff, nothing. Called a friend to tow me and when he pulled up said my lights were blinking. Duh - turned the alarm off with the key. Paid him for his gas and bought him lunch.
If you remove the horn alarm look out for this.
Unread 07-06-2012, 07:12 AM   #11
grghunter4
Been there sat after a camping trip from this but iit killed my battery to
