alarm horn , interior light work with ign switch on or acc but not off position? - JeepForum.com
post #1 of 7 Old 09-21-2009, 05:57 AM Thread Starter
joe_blow
99 GC loredo
my alarm horn doesnt sound or flash lights when I lock/unlock truck via keyfob - BUT it does lock/unlock doors,
interior lights dont work, center display doesnt work, with ignition in off position BUT once key is on or acc
position the interior lights and overhead console turn on an eberything works fine?
I also remember messing with key fob and with ignition on or acc panic sounded horn..
Not sure if a ignition switch can do this and dont know how to check?
Anyone seen this or know how to fix?
thanks
joe
joe_blow is offline
post #2 of 7 Old 09-23-2009, 05:36 AM Thread Starter
joe_blow
Anyone have ideas or suggestions????
thanks!
joe_blow is offline
post #3 of 7 Old 09-23-2009, 05:55 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
You more than likely have a bad wire somewhere between the battery and BCM. I had the exact same issues when I bought my 2000. I wasnt too worried about it at first since it was just more annoying than anything. But it eventually affected my Sentry Key Immobilizer System and disabled my Jeep completely. I had to have it towed to the stealership thinking I would need the SKIS reprogrammed to my key, but they found a bad wire, fixed it, and everything worked again. They charged me $180 for everything.
~James
ezflip is offline
post #4 of 7 Old 09-23-2009, 06:02 AM
Itsjustme2see
Check in the owners manual for programmable features.
Itsjustme2see is offline
post #5 of 7 Old 09-24-2009, 11:06 AM Thread Starter
joe_blow
Did not find any programmable features but options in the over head does show flashing lights and horn ON...
Question.. Can it be the stock factory security system? Cant find any specific fuse or detail about it...
I am toying around testing things.. keyfob only locks/unlocks door locks .. no flashing lightd or horn, and panic doesnt do anything.. Maybe I am wrong, but I tried to arm alarm while sitting inside, waited 1 minute
and opened door... nothing happened..
Anyone know a way to check the stock alarm to see if it died or something? truck runs fine..
thanks!
Joe
joe_blow is offline
post #6 of 7 Old 09-24-2009, 11:29 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
thanks!
Joe
My Jeep did the same things to the letter! Refer to my previous post for your solution.
~James
ezflip is offline
post #7 of 7 Old 09-25-2009, 06:07 AM Thread Starter
joe_blow
Your talking about harness between the Junction block bcm plug and battery?
If you recall any details it can help!
thanks
joe_blow is offline
Horn doesn't work when pressing steering wheel; horn does chirp when arming/panic cmassey_2006 WK Grand Cherokee & XK Commander Forum 10 07-31-2017 11:00 PM
Door Switch Causing Electrical Problems with Alarm & Interior Lights sadjgcowner ZJ Grand Cherokee Forum 7 11-02-2009 04:36 PM
Change the oil and the Alarm/Horn goes off... danglenode ZJ Grand Cherokee Forum 7 06-29-2008 04:57 PM
Rear hatch interior light switch TiminOR ZJ Grand Cherokee Forum 0 01-15-2008 02:33 PM
Security Alarm Horn t_guenther ZJ Grand Cherokee Forum 1 06-14-2007 10:25 AM
