Airconditioner doesn't cool car - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Airconditioner doesn't cool car
Ruffstuff 10 year saleSave up to 10% on Rugged Ridge - ExtremeTerrain!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-02-2003, 05:42 PM   #1
Keith F
Had it checked by dealer. Say no problem. Takes 20 minutes at highway speed to begin to feel a little cool air in back. Is system too small for cabin space? Passengers miserable. Anybody else have trouble with this?
Keith F is offline   Reply With Quote Quick reply to this message
Unread 08-02-2003, 06:10 PM   #2
Stocker
You can get more air to the rear passengers by directing some through the under-seat vents, and by aiming the center dash vents between the front seats. The system should be adequate, but if yours isn't cooling enough, I'd skip the dealer (unless you're still in warranty) and take it to an A/C shop. The system may be low on R134a and just need a recharge. If it's a pro shop they'll check it out, charge it if necessary, and add oil and dye as needed.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline   Reply With Quote Quick reply to this message
Unread 08-02-2003, 06:16 PM   #3
Keith F
Thanks for the response. Forgot to say it's a 2002. Had it recharged at dealer last summer and this summer and all tests done etc. The temp readings they get are good and compared to a floor model the power at vents felt same. Still interior remains sooo hot!
Unread 08-02-2003, 06:33 PM   #4
Stocker
If your rear windows aren't already dark tinted, have that done - it helps.
Stocker
Unread 08-02-2003, 08:11 PM   #5
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Tinted window help any A/C cool the car.
Hunter
00 4.7 Laredo...KYB gas shocks, ADDCO rear sway bar and Firestone Destination tires.
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote Quick reply to this message
Unread 08-03-2003, 12:21 AM   #6
whitevette
Re: Airconditioner doesn't cool car
What's your vent temperature?
Darkness is deaths ignorance, and the Devils time.
'96 Grand Cherokee Laredo
'93 Taurus SHO
'77 Corvette L-48
'74 Land Cruiser FJ40
whitevette is offline   Reply With Quote Quick reply to this message
Unread 08-03-2003, 07:22 AM   #7
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The AC should be super cold. IF not then, you've got a leak somewhere. It may be very small. After only three years, I had to recharge my freon or whatever the coolant is called now.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
