Air Vents - JeepForum.com
post #1 of 7 Old 09-07-2012, 12:04 PM Thread Starter
rob84044
Air Vents
Hello. I have a serious issue i feel.
To start off, only my face vents and my defroster vents will blow air thru them. None of the other options for the air veents will work.
Second off, whenever I start going about 40 miles an hour or higher ( whenever I start to involve higher gears, (it is an automatic) ) the air will go from the face vents to the defroster vents. And once I slow down or finally pass thru to the higher gear, the air will return to the face vents.
And now only recently the face vents arnt working. It is boggling my brain..
rob84044 is offline
post #2 of 7 Old 09-07-2012, 12:16 PM
PolkaPower
Sounds like it could be a vacuum leak. Check all of you lines under the hood. Just a guess though.
PolkaPower is offline
post #3 of 7 Old 09-07-2012, 12:26 PM Thread Starter
rob84044
What do these lines look like?
Are they the two tubes going into the fire wall?
rob84044 is offline
post #4 of 7 Old 09-07-2012, 12:32 PM
melk
The vents are controlled by vacuum pressure.
This vacuum line terminates under the battery tray, where it must be securely attached to the box.
I would check that first.
edit, the vac lines are small-diameter black rubber hose. They attach to the intake manifold. Trace back the one that goes along the firewall and passenger side fender to the box under the battery tray as I described above.
melk is offline
post #5 of 7 Old 09-07-2012, 12:58 PM
mtsgsd
I just fixed that problem my self. The hose was fitting too loosely at the vacuum reservoir under the battery. For some reason this is not a barbed fitting either. It's only about 18" or so of rubber hose that connects to a network of plastic lines, so It's a cheap fix too if that's the only issue.
mtsgsd is offline
post #6 of 7 Old 09-24-2012, 12:46 PM Thread Starter
rob84044
can u post a picture of which lines?
I will post a picture later tonight with something i think you all are talking about.
rob84044 is offline
post #7 of 7 Old 09-24-2012, 01:07 PM
Glasssplinter
1994 ZJ
There was also a TSB on this that you need to add a check valve in the line that goes through the firewall to the climate control selector. This was the link someone else had posted
http://dodgeram.info/tsb/1996/24-01-96a.htm
'94 ZJ, 4.0L, 231 TC
Icom V-8000 with 1/4 wave
Glasssplinter is offline
air , automatic transmission , firewall , speed , vents
mist/smoke coming out of A/C Vents and Dash vents scambi ZJ Grand Cherokee Forum 13 06-25-2015 12:45 AM
Air Vents andrew44 WK Grand Cherokee & XK Commander Forum 14 02-27-2013 01:07 PM
vents? Ender42 ZJ Grand Cherokee Forum 1 09-13-2009 08:24 PM
vents?!? 2000_WJ ZJ Grand Cherokee Forum 0 07-01-2009 10:13 AM
Vents 95GCV8 ZJ Grand Cherokee Forum 4 05-15-2006 10:47 PM
