air filter box - JeepForum.com
post #1 of 3 Old 10-06-2003, 06:42 PM Thread Starter
pygocentrus
air filter box
on my 98 grand cherokee, on my air filter box, theres this cold air tube that connects to the grille. can i take it off? it seems skinny and not supplying enough air. should i remove it? it seems easy to remove.
98 GC limited 5.2 4x4
mods: 3 chamber magnaflow
upcoming mods: throttle body, intake, and headers, 3" lift, tires, and system (if I can save enough $)
pygocentrus is offline
post #2 of 3 Old 10-06-2003, 09:08 PM
Joseph Humphrey
Joseph Humphrey's Avatar
tell you what you can (and rightly should) do:
just take the air box out of the engine, grab your drill and a large bit and a saws all or jig saw and cut out the sides of the box leaving enough on the corners to support the filter on top. basically a poor man's cold air intake. as long as you have a high flow filter like the k&n's it will work out just fine.
The Almighty 2" BB Jeep Club Member #34 (no more BB)
Silver 98 ZJ 4.0 I-6
K&N FIPK Gen II
JKS Adjustable Track Bars F and R
JKS Adjustable Control Arms
JKS Quicker Disco's
Kevins 3.5" Lift Kit w/ MX-6 Shocks
US Wheel 15x8 10 spoke black Steelies, 31" BFG AT KO rubber
Joseph Humphrey is offline
post #3 of 3 Old 10-09-2003, 09:39 AM
PC_96_GCL_ZJ_OZ
I am just going thru this procedure myself, I have a 96 ZG GCL 4.0 and have just fitted extractors and a SS 2 1/4" hiflo cat and exh, bored the throttle body and fitted the K&N flatpad. How resitrictive is that pipe at the front of the air box! You will note that in that part of the engine bay that it gets very hot, I am going to build some sort of wider cold air intake ideally wider and with no bends into the box. My most likely fitting will be some sort of PVC round pipe pointed right up to the front grille.
This engine bay gets so hot that I have even seen some 4.0's with thermal lagging around the pipe from the box to the throttle body!
Maybe what is really needs is a WRX style bonnet scoop!
PC_96_GCL_ZJ_OZ is offline
fram oil filter vs mopar oil filter wj03grandy ZJ Grand Cherokee Forum 76 02-21-2015 10:37 AM
Oil Filter/Air Filter advice for 3.0 CRD DarrylFlynn WK Grand Cherokee & XK Commander Forum 5 12-23-2009 08:02 AM
Cone *air* filter pre-filter wrap; Useful? coultond WK Grand Cherokee & XK Commander Forum 6 09-18-2009 01:14 PM
What is this filter?,... pls help sharkbiter32 ZJ Grand Cherokee Forum 5 03-03-2009 12:58 AM
oil in air filter? GettinStuck ZJ Grand Cherokee Forum 1 05-19-2005 07:19 PM
