Air in the cooling system - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Air in the cooling system
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-20-2007, 10:29 PM   #1
lma1973
How does it get there? I just had radiator, water pump and thermostsat replaced. For the first few hours the bubbling noise that had previously been going on behind the dash disappeared, but now its returned already. Whats up with that?
1994 Grand Cherokee Limited 4x4 5.2 V8
lma1973 is offline   Reply With Quote
Unread 07-21-2007, 01:30 AM   #2
SpeedyCat3
Survivor
SpeedyCat3's Avatar
You probably still have air in the system.
The bubling will be present when the water boils.
If you can get the Heep on an incline so that the radiator cap is the highest poin in the system, and keep refilling so that all the bubbles scape, or most of them. You need to get the engine to operating temperature so that the t-stat opens and water circulates around the whole system. Run the heater too.
Top the coolant reservoir, and you should be good to go.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
My 97 ZJ Build
SpeedyCat3 is offline   Reply With Quote
Unread 07-21-2007, 09:01 AM   #3
lma1973
Thanks...i'll burp it today and give it a shot!
