Air Conditioning and vacum seal - JeepForum.com
post #1 of 2 Old 09-24-2012, 09:06 AM Thread Starter
rob84044
I took out my battery container and looked at my AC lines, and the two connectors. One was loose and was very...rigid...so I took off the loose one adn was wondering if htat is how they are supposed to be? Well any help/info would be helpful.
rob84044 is offline
post #2 of 2 Old 09-24-2012, 11:15 AM
Glasssplinter
1994 ZJ
If you're talking about the vacuum lines that run under the battery tray yes they should be rigid line. Most of the vacuum lines are that rigid line and it ends up cracking after several years. It needs to be connected to that reservoir under the tray or your cruise control and climate control won't work properly.
'94 ZJ, 4.0L, 231 TC
Icom V-8000 with 1/4 wave
Glasssplinter is offline
air conditioning , battery , battery bracket tray , connector , vacumm leak
not sure where this vacum line goes.... leog1985 ZJ Grand Cherokee Forum 17 07-16-2013 01:04 PM
vent or vacum problem?? unkleabe55 ZJ Grand Cherokee Forum 5 07-21-2012 07:49 AM
Changing out the front pinion seal and right side seal on the transfer case? LelandGray WK Grand Cherokee & XK Commander Forum 10 01-17-2012 08:15 AM
AC & Cruise vacum sullivanpunk ZJ Grand Cherokee Forum 0 06-10-2008 09:23 PM
1993 Oil Filter Adapter seal kit is not #04720363. What is the correct seal kit ??? Panchojeep ZJ Grand Cherokee Forum 2 04-11-2008 09:38 AM
