Air Conditioning just failed, help please.
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full |
#1 | |
I just got my Jeep back on the road after replacing the PCM. I drove it today and after about an hour on the hiway I heard a loud screech followed by increasingly warmer air coming from my a/c vents. I pulled over and looked at the compressor and sure enough the clutch looks like it melted.
What should I do? Replace it with a remanfactured compressor w/clutch or try to replace the bearing and clutch? Thanks in advance
#2 |
take the belt off and see what kind of shape the shaft is in by doing an end play check.
if it feels okay, i'd go for a clutch replacement if you can find one.
97 ZJ, 4.0, 2WD, 3.73s. |
#3 |
Clurch bad or did the compressor lock up?
You can purchase new compressors for @ $150, but naturally the system would then need to be evacuated and recharged. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
