Quantcast Air Conditioning - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Air Conditioning
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 08-26-2003, 08:36 PM   #1
Willie1470
Air Conditioning
About six weeks ago, I had the air conditioning system recharged. Recently it has been producing only slightly cool air. Any suggestions where I might look first.
Thanks for anticipated help,
Willie
Willie1470 is offline   Reply With Quote
Old 08-27-2003, 05:31 AM   #2
whitevette
Take it back and *****.
Darkness is deaths ignorance, and the Devils time.
'96 Grand Cherokee Laredo
'93 Taurus SHO
'77 Corvette L-48
'74 Land Cruiser FJ40
whitevette is offline   Reply With Quote
Old 08-27-2003, 06:23 AM   #3
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Exactly,
if you have already paid for it, make them recharge it again.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 08-27-2003, 10:32 AM   #4
automan25
All the complaining in the world won't make your A/C system work any better, no matter how many times they recharge it. It sounds to me like you have a leak in your system. Chances are when your system was recently recharged your mechanic put a UV dye into the mix to help identify potential leaks. Take the vehicle back to your mechanic and get him to use a UV light to try and detect the leak.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline   Reply With Quote
Old 08-27-2003, 07:40 PM   #5
Stocker
Yup... and since they just charged it 6 weeks ago and didn't find the leak (I know, no dye in it then, but they might have leak detection equipment), play on their sympathy and ask if they'll give you a break on the second recharge.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline   Reply With Quote
Old 08-27-2003, 07:48 PM   #6
automan25
There is obviously a leak in the system somewhere. This needs to be fixed before you recharge the system again.
Old 08-27-2003, 07:53 PM   #7
JEEPTECHNICIAN
First of all, do not take it back and *****. That will get you nothing but a goodbye and dont come back. Just because someone charges your A/C they should be responsible cause it leaked out. If it is leaking in a place wher you cannot see a visible leak you cant hold the garage responsible. They did not put the leak there. Second what year is your GRAND? And I will tell you what to do. And also how many miles are on it?
JEEPTECHNICIAN is offline   Reply With Quote
Old 08-27-2003, 09:27 PM   #8
Willie1470
Thanks, My Grand is a '98 with 55,100 miles.
Old 08-27-2003, 09:29 PM   #9
whitevette
But it is their job to detect the leak in the first place. Pressurize the system with nitrogen until you find the leak. Fix said leak, evacuate, recharge and collect your money.
'93 Taurus SHO
'77 Corvette L-48
Old 08-27-2003, 10:03 PM   #10
JEEPTECHNICIAN
No its there job to do that if there is no visible leaks found under a normal a/c recharge. And why would you pressurize a mobile a/c system with nitrogen. Thats what tracer dye is for, a none misdiagnosis leak detection system. sniffer's suck. Tracer dye dont lie. and lord help the technician who uses a sniffer where someone has put hotshot in a a/c system and he finds the leak.
cause there might be a slight explosion. and FYI what you are talking about is a repair not an a/c service. If I done what yuou are talking about just to leak check it would cost you 1.4 hours labor to evacuate and recharge and .5 hours to leak test and 30.00 dollars for freon and in our dealership that would cost about a total of 170.00 dollars.
Old 08-27-2003, 10:13 PM   #11
JEEPTECHNICIAN
Willie1470 if you have a ZJ Ym's- 93-97 and some 98's it is about 95% the evaperator coil, wich dye or anything else would do no good then. But chrysler extended the warranty 0n them YM's to 7yr 70k mile warranty on the evaperator. And anybody who has paid to have this fixed while it was still under warranty and have the proper paper work to prove it can send it to chrysler and request a refund.
Old 08-27-2003, 10:21 PM   #12
Willie1470
Thanks, JeepTechnician. I'm bringing my Grand to Jeep tomorrow and the tech who charged it is going to work on it (he is a friend of the family and I'm sure that he'll do right by me) I'll keep you posted.
Willie1470
Old 08-28-2003, 07:37 AM   #13
whitevette
Gotcha.
<-- Blurred the lines between a full blown service and a simple recharge. Working for a fleet instead of private individuals, procedures change as nobody *****es about what we do, so we do everything. If the freon has leaked out, we find out why instead of just refilling it.
'93 Taurus SHO
'77 Corvette L-48
Old 08-28-2003, 10:20 AM   #14
JEEPTECHNICIAN
you don't have me. there is a big difference between a fleet service and a repair shop. fleet companies have contracts with there customers. so there going to get paid regardless. let a paying customer go into a shop and say I want my a/c charged up and you take it back there and come back and tell them they owe you 170.00 for finding a leak and another 75.00 - 100.00 for the repair on the leak. they will tell you I did not authorize that repair all Iwanted was the a/c charged up. call it a service or charge but it is defined the same way. charge the system, test the performance, look for visible leaks, if there are none seen have a great day. the way you describe it works in a fleet shop, you dont have to wait for authoriztion you all just fix it under the contract you have with your customer. kinda like warranty for us we dont need authorization to fix anything under warranty we just fix it. you have a misunderstanding on what goes on in a real repair shop where the customer pays out of there pocket. of course a real technician would know what a visisble leak is and address it at the time of service to the customer. real technicians do not charge it and see a visible leak and let it go with out explaning to the customer that they have a known leak and that we are not sure how long the freon will stay in the system but it's there call on wether they want to fix it or let it ride and see how long it last. it may last a week it may last 3 months. but here is the cost of the leak repair and if you do not want to fix it here ya go hope it last for you. so now you see the difference betwen fleet and repair shops. maybe you guys call it a simple recharge, but that was back in the 70's. there is no such thing as a simple recharge anymore. a real shop has a 12 and 134 machine that does the work for them. there is not a set of old tyme manifold gauges in our shop. by law you are required to have a recycling machine both 12 and 134. i have never seen a full blown a/c service that you evacuate and recharge an a/c system. you want be doing many services for around 200.00 bucks.
Old 08-28-2003, 11:49 AM   #15
Willie1470
I went ot Jeep and they diagnosed it as an evaporator coil and the cost is $750 to replace. Is there some where you can guide me to see if my car is under the extended warranty? Could you also tell me ZJ Ym's are? Thanks a lot, you are making this whole thing into an adventure.
Willie
Glock Forum
