AGH! i got a leak somewhere! - JeepForum.com
post #1 of 11 Old 09-05-2003, 10:11 AM Thread Starter
pygocentrus
under the passenger floor mat, it is soggy and wet. my co-worker said its the AC. am i able to fix it, or should i punk the dealer.
pygocentrus is offline
post #2 of 11 Old 09-05-2003, 01:59 PM
Bird
Check your drain tube - probably plugged up. just look in the engine compartment on the passenger firewall and you'll see it sticking out. Can usually just stick a small screwdriver up in it and clean it out.
99 Grand Cherokee 4X4
93 Ford Ranger 4.0
Bird is offline
post #3 of 11 Old 09-05-2003, 04:43 PM Thread Starter
pygocentrus
cool, what does this drain tube look like? im at work right now, could i use a pen to un-clog it?
also my AC is making a funny noise, it sounds like i have 42" tires.
post #4 of 11 Old 09-07-2003, 08:26 AM
CATMAN2
I AM ALSO HAVING THE SAME PROBLEM. I FOLLOWED THE INSTRUCTIONS AND THE PROBLEM STILL EXISTS. I HAVE 96 GC AND I HAVE LOOKED ALL OVER IN THE ENGINE AND FIREWALL AND HAVE NOT LOCATED ANY DRAIN PLUG. THE MANUAL SHOWS A DRAIN PLUG BUT THERE ISN'T ANY FOR MY GC. DO ALL 96 GC HAVE DRAIN PLUG ON THE FIREWALL ?
CATMAN2 is offline
post #5 of 11 Old 09-07-2003, 04:01 PM Thread Starter
pygocentrus
i cant find mine either, is it possible that when the dealer steam cleaned the carpets, water got stuck under the mats? i turned on the AC full blast and ripped up the carpets to see where the leak is coming from. when i did lift up the carpet, water just drips from the carpet itself, but not from any source above that. i tried the tube that blows the cold air to the back seat, but no water found. i dried up all the water (well most) and im gonna drive all day with teh AC on and lift up the carpet again to see if theres anymore water. i really hope its just water from the cleaning.
*hopes*
post #6 of 11 Old 09-07-2003, 10:47 PM
CATMAN2
[*hopes*[/QUOTE]
TRUST ME, IT'S NOT FROM THE CLEANING. WHENEVER YOU FIND YOUR DRAIN PLUG OR A SOLUTION THIS WET PROBLEM.......PLEASE,PLEASE, PLEASE LET ME KNOW !
CATMAN2 is offline
post #7 of 11 Old 09-08-2003, 12:35 AM Thread Starter
pygocentrus
youre right. its leaking again. i cant find the damn drain thing. i ripped up the carpets, but found no drain of any sort. just metal.
post #8 of 11 Old 09-08-2003, 10:12 AM
automan25
The evaporator drain plug drains into the frame of the vehicle. That is why you cannot see it sticking through the firewall. Jeep issued a Technical Service Bulliten a few years ago to help remedy the problem of a clogged drain tube. Here it is:
http://home.sc.rr.com/janet/TSB/24-06-96.htm
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #9 of 11 Old 09-08-2003, 11:06 AM Thread Starter
pygocentrus
thanks very much!
post #10 of 11 Old 09-08-2003, 11:07 AM Thread Starter
pygocentrus
1 wuestion, whats a 5255217 plug?
post #11 of 11 Old 09-08-2003, 02:53 PM
automan25
I assume it's a part that you could buy from your chrysler dealer for about $100.00. Most people, however, just cover the hole with electrical tape.
Anybody ever used Bar's Leak or Alumaseal radiator stop leak? scarthearmada6 ZJ Grand Cherokee Forum 23 05-02-2014 03:10 PM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 04:58 PM
2003 JGC I6 codes 442 medium leak and 455 large leak samsdad ZJ Grand Cherokee Forum 0 08-28-2007 11:17 AM
fron driveshaft join leak and pinion seal leak. GRDCHRKE555 ZJ Grand Cherokee Forum 1 12-12-2006 08:10 PM
engine light - Evaporative Emission Control System Leak Detected (very small leak) sanboy ZJ Grand Cherokee Forum 3 03-14-2006 09:42 AM
