Aggrivating "skip" at highway speeds - JeepForum.com
post #1 of 9 Old 08-18-2006, 01:54 PM Thread Starter
KC8RXQ
I'm looking for advice on a situation that's been more of an aggravation than a real problem - so far.
My 2004 JGC Ltd. (@ 46k miles, 4.7L stock all the way) has developed what I call a "skip" or "burp" for lack of a better description. It appears during highway driving, especially during extended driving at the same speed. I know it's not the road conditions because I actually feel this sensation regardless of whether I'm driving on concrete or asphalt - smooth or moderately rough. [I may be too sensitive to things like this but I get the feeling that most of the Jeep owners that subscribe to this forum are "in tune" with their vehicles.] The frequency of this "skip" is once or twice every few minutes and like I said before, it's more of a nuisance than a problem; at least at this point. My Jeep is well maintained - not abused, routine service has always been performed and the vehicle hasn't been off road. While the standard warranty has run out, I still have the DCX 7yr/70,000 mile drivetrain warranty. I'm more curious as to whether anyone else has experienced the same situation and how it was addressed.
Thanks to all the moderators for a well maintained forum, and to those who take the time to respond to my inquiry.
Ed/KC8RXQ
2000 JGC Laredo 4.0L/Selec-Track (stock)
2004 JGC Limited 4.7L Quadra Track II (stock)
but someday.........
KC8RXQ is offline
post #2 of 9 Old 08-18-2006, 02:01 PM
Varkyl
No where near stock
Varkyl's Avatar
It sounds like there is a slight misfire. Have you tried pulling the codes? Or even running a different brand or grade of fuel.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline
post #3 of 9 Old 08-18-2006, 02:05 PM
Diehard
Diehard's Avatar
Try using some STP fuel injector cleaner when you fill up next time. Have you changed the plugs at 30,000?
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker.
Diehard is offline
post #4 of 9 Old 08-18-2006, 02:06 PM
sand zj
sand zj's Avatar
Turn the key on-off-on-off-on and check for codes (on oddometer or other display) DO NOT START IT each time, just to ign. The codes will be a P___, write down the codes then let us know what they are.
Dan
If you don't get stuck, keep trying!
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline
post #5 of 9 Old 08-18-2006, 02:35 PM Thread Starter
KC8RXQ
Aggrivating "skip"...
I've already tried a can of Seafoam in the gas tank and went to a few tanks of 89 Grade gas. I'm not hesitant about putting another can in the tank but I wasn't sure just how often I could do it without doing any damage (my ignorance shows). I checked for the engine codes, through the ignition switch procedure, and the word "done" came up on the display. I take that to mean that there weren't any codes to process.
The only thing I haven't tried is replacing the spark plugs which hasn't been done before. I'll take care of that issue and see how things turn out.
Thanks to all for the replies and enjoy your jeeps.
Ed/KC8RXQ
KC8RXQ is offline
post #6 of 9 Old 08-18-2006, 03:45 PM
rm2001wj
rm2001wj's Avatar
I'll bet it doesn't do that when the AC is turned off. At least mine doesn't. Seems to be the compressor going on and off. I've been told that there is not much that can be done about it.
rm2001wj is offline
post #7 of 9 Old 08-18-2006, 04:10 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
Hmmm... I was going to say TPS sensor... but that generally throws a code...
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #8 of 9 Old 08-18-2006, 09:06 PM
zjhitman
46K on the original spark plugs. That's the first thing I would change. It may be as simple as that.
zjhitman
zjhitman is offline
post #9 of 9 Old 08-18-2006, 09:06 PM
trickle26
trickle26's Avatar
I was thinking TPS as well...I had the same kind of surge/skip at highway speeds that you are talking about and it was a bad TPS sensor. It did not throw a code. I was checking the codes after the problem occurred and didn't get anything. Replaced the TPS and problem gone... I am not sure about the TPS on the 4.7. It does seem like a bad TPS can cause a lot strange idle/surging problems.
The A/C cycling on/off like rm said could also be the source.
97' ZJ Limited V8 - 5.2 liter
94' YJ 4.0 ho -SE -
past jeeps: 89' YJ
87' YJ Laredo
88' YJ Sahara
90' XJ Limited
trickle26 is offline
Vibration at highway speeds droldsw32 ZJ Grand Cherokee Forum 0 11-15-2009 01:53 PM
Bad vibs when braking AND at highway speeds JasonYeo ZJ Grand Cherokee Forum 1 03-26-2009 04:04 PM
5.9 dies only at highway speeds. . . help!! pricer5.9 ZJ Grand Cherokee Forum 2 01-18-2009 11:20 PM
Weird sound at highway speeds... Redsand ZJ Grand Cherokee Forum 1 03-26-2008 05:12 PM
Binding Feeling at highway speeds mikeumkc ZJ Grand Cherokee Forum 1 05-06-2006 11:19 AM
