AGAIN-This grinding is getting annoying - JeepForum.com
post #1 of 2 Old 03-09-2004, 06:03 PM Thread Starter
Astorm
This is really starting to annoy me. I've had a couple posts for this in the past, and the problem remains, even after diagnosis and repair. It was diagnosed as a tranny solenoid pack....it wasn't that. Well, we've narrowed the grinding noise down. Its the transfer case. It does it when its cold, but its taking longer and longer to go away. I have the Quadra-Drive system with the 247 t-case. I just changed the fluid. Any ideas why its grinding, or how I can fix it?
2000 JGC Limited 4.7
Quadra-Drive
Addco
Flowmaster 50-Series
K&N FIPK/RamIt
Every Option
Astorm is offline
post #2 of 2 Old 03-10-2004, 05:58 PM
CaptainK
Well my friend, you should probably start looking around salvage yards for a replacement unless you have the knowlege or a buddy who does to repair that one. Did you use only the specified lube? Jeeps are very particular about what is used in their transmissions and if you try to cut corners, you can figure on getting a lesson.
The Captain
97 GC
155000 happy miles
CaptainK is offline
annoying idle... lakailimited06 ZJ Grand Cherokee Forum 33 06-11-2008 10:38 PM
how annoying!! stump buster ZJ Grand Cherokee Forum 0 04-16-2007 01:10 PM
Roaring!!!! man this is annoying... Reloader77724 ZJ Grand Cherokee Forum 23 08-01-2006 11:01 PM
How annoying... MidniteSquirrel ZJ Grand Cherokee Forum 11 03-01-2006 10:02 PM
annoying adam84 ZJ Grand Cherokee Forum 4 01-20-2006 06:32 PM
