aftermarket hitch vs factory hitch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > aftermarket hitch vs factory hitch
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueRough Country Lift Kits and Parts!
Unread 09-10-2005, 04:40 PM   #1
dharmabum
I just picked up a 2002 Grand Cherokee and it is in desperate need of a hitch. I know the factory ones sit up higher in the bumper and there is the trim piece that goes around them and they look pretty nice but to get all the dealer only parts it starts to add up while an aftermarket hitch is a little more reasonable. Now I would rather go with the factory parts but if anyone has a picture of an aftermarket one showing how far down they actually hang and how bad they look it would make my decision easier or maybe you could convince me to go aftermarket. I have done alot of searches but still cant find a good picture of an aftermarket one either.
dharmabum is offline   Reply With Quote
Unread 09-10-2005, 05:14 PM   #2
McGR
2007 XK Commander
I have a Hidden Hitch brand hitch on my WJ. I picked it up cheap from JC Whitney for about $100. From what I can tell it sits at about the same height as factory. This is because with the Hidden Hitch design you have to cut some bumper facia, so you basically end up with a similar set up to factory. I've had Hidden Hitches on three vehicles now and have been very satisfied. They truly do design them so they are fairly inconspicious, as opposed to some I've seen out there which hang about 3" lower than the bumper.
BTW, I can probably compare my hitch to a stock one later on tonight, some friends should stop by with their WJ/factory hitch. If I get the measurement I'll post the results.
McGR is offline   Reply With Quote
Unread 09-10-2005, 05:30 PM   #3
grovesj2
Ive got a regular after market hitch and I like where it sits. Before I put the lift and bigger tires on my Jeep it was the perfect height for my boat trailer. If you have a trailer that sits higher than you can just get a hitch with a 2" rise, that would put the ball about the same height it would be if you had a factory hitch. Theres no denying that the factory hitch looks better being hidden but you have to ask yourself wether its worth the extra money just for looks with no additional functionality.
Im going to attempt to attach a pic, if it dosent work you can PM me your email and Ill send the pic to you.
[IMG]E:\Jesse\My Pictures\Jeep\After 2 inch and tires\jsjfihernvdi 001.jpg[/IMG]
grovesj2 is offline   Reply With Quote
Unread 09-10-2005, 05:31 PM   #4
grovesj2
So much for my effort at attaching a pic...
Unread 09-10-2005, 09:36 PM   #5
McGR
2007 XK Commander
OK, I compared my hitch to an OEM one this evening. The OEM hitch sits about 1.5" higher than my Hidden Hitch. So, if clearance is a big issue, the OEM is best. If functionality and economy are most important, go with an aftermarket unit.
Unread 09-10-2005, 10:11 PM   #6
dharmabum
Thanks for checking it out, do you know which Hidden Hitch you have? It seems they make two, #87594 which is a standard design hitch, and #70594 which is a round tube style hitch? I have used their hitches before and been very happy with them too so if it would be more economical and still look good I may go with them again.
Unread 09-10-2005, 10:13 PM   #7
dharmabum
Hey if you could email me any pics of it that would be great, my email is dharmabum@comcast.net. Also do you know what brand of hitch it is you have?
Unread 09-10-2005, 10:53 PM   #8
McGR
2007 XK Commander
I guess I have the square style. I'm not sure what the tubular style would buy you anyway, as all you can really see on the type I have is the receiver exiting the facia. It seems to me the round tubing would be hidden, assuming the design is similar to the square one. I'll see if I can take a pic tomorrow and post it.
Unread 09-10-2005, 11:38 PM   #9
grovesj2
I have the tubular Hidden Hitch and it isnt actually hidden...it sits right below the bumber as youll see in the pic I sent.
Jesse
Unread 09-11-2005, 07:00 AM   #10
dharmabum
If you could snap a pic of the Hidden Hitch square style that would be great. You can even email it to me at the address above if its easier than posting.
Unread 09-11-2005, 07:02 AM   #11
dharmabum
Jesse
Thanks for the pic, I don't think that hangs down too far at all and your jeep looks pretty nice with the BB and 265/75s. Got me thinking about doing that too now
Unread 09-11-2005, 02:56 PM   #12
McGR
2007 XK Commander
Here's an image of my hitch:
EDIT: Anyone know why my hosted image isn't showing. I used the Insert Image icon in the editor. Any other tricks to get them to display?
Unread 09-11-2005, 03:04 PM   #13
Woody
Retired back to Bowties
Woody's Avatar
1985
You need to be a member for 30 days and have at least 50 posts to post your pictures.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline   Reply With Quote
Unread 09-11-2005, 03:05 PM   #14
anticrombie
Bah on you Woody!
anticrombie is offline   Reply With Quote
Unread 09-11-2005, 03:07 PM   #15
Woody
Woody's Avatar
1985
You gotta be quick!
Woody
