Aftermarket audio system issue.. - JeepForum.com
post #1 of 13 Old 04-02-2013, 06:43 PM Thread Starter
steviep6
2007 WK
Ok well I put in some subs new speakers and a new headunit but also kept my amp hooked up. I did that by using the intergrated harness connecting rcas in the rear of my deck and sending the signal wire to the amp harness. My problem is that my speaker volume is like half of the volume that the stock deck was when installed using the stock amp. This is what I'm confused with it makes no sense. Any advice?
steviep6 is offline
post #2 of 13 Old 04-02-2013, 06:59 PM
Myusername1674
Are you using the stock amp??
the stereo in mine was set up by the po, going from an aftermarket head to an alpine amp, which splits it off to the speakers and the subs. May need an amp with more power.
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #3 of 13 Old 04-02-2013, 07:57 PM
bigb229
Make sure you sent power from your receiver amp wore to the stock amps feeder wire
bigb229 is offline
post #4 of 13 Old 04-02-2013, 08:11 PM
Mickey_D
Remember the stock amp uses speaker level inputs. Not the RCA connections out of the aftermarket head unit.
I put a Sony head unit in mine. Blaupunkt speakers in the front, Pioneer in the rear, and a Kenwood home stereo 160W sub in the back powered by a Harbor Freight inverter.
It's headache inducing at 50% volume.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #5 of 13 Old 04-02-2013, 09:15 PM
Edwardmiller221
Nice I have alpine head, 650 watt Rockford fosgate amp hooked up to two component fosgate speaks in front and mounted two fosgate 9x11 off the back trunk pillars. One 12 inch sub hooked up to a 1200 watt amp. Have not been able to turn all the way up yet. 18 is the highest I will go and at that level the hair on your head is ticking. You can feel the vibrations move through you. Petty amazing.
Edwardmiller221 is offline
post #6 of 13 Old 04-03-2013, 01:19 AM
thetammon
I have a Sony deck, and I bypassed the stock amp so my speakers run off the deck. Front and rear speakers are alpine sps 610 I think, then I have 2 12" jl subs that run off a Jensen 900 watt amp.
Sent from something using JeepForum
thetammon is offline
post #7 of 13 Old 04-03-2013, 06:26 AM Thread Starter
steviep6
2007 WK
Well I'm using the stock amp still but without all this installed the stock deck was literally twice as loud with the stock amp. I'm thinking about wiring speakers right to the deck and say screw the stock amp after work td. The subs work amazing 2 jl w3 in jl audio box powered by arc audio amp.
steviep6 is offline
post #8 of 13 Old 04-03-2013, 06:45 AM
sebian
Stock deck, amp, and speakers are all 2 ohm. Aftermarket are 4 ohm, so to get better sound you will need to replace the stock amp.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #9 of 13 Old 04-03-2013, 07:28 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Rca output voltage is less than the stock line level outputs. Effectively cuts the gain in half.
ratmonkey is offline
post #10 of 13 Old 04-03-2013, 04:49 PM
Mickey_D
We've answered your question twice already.
If you're using the stock amplifier, you won't use the RCA connections on the new head unit except to your sub amp. Disconnect the RCA connections from the stock amp and wire in the speaker outputs from your new head unit into the stock amp. In other words, wire up your 4 speaker outputs from the head unit into the stock harness in the dash, as if there was no stock amp there at all. The stock amplifier DOES NOT use RCA inputs. It uses speaker level inputs. I'm trying to word this as many diferent ways as possible so there is no confusion here.
That's what I've done and as I posted before mine is headache inducing at 50% volume on a ****ty 10 year old Sony Xplode head unit.
________________
#4
Mickey_D is offline
post #11 of 13 Old 04-03-2013, 11:56 PM Thread Starter
steviep6
2007 WK
Yea the damn stock amp was resisting my rms badly. Just ran speaker wire directly into the deck and called it a day sounds so much better. This is my first jeep, one thing I learned td unless ur running a amp for speakers good luck running all the spkr wire behind deck NO extra room really in door door jams/dash..
steviep6 is offline
post #12 of 13 Old 04-04-2013, 10:57 AM
Mickey_D
I just used the original wiring from the factory. Got one of those Scoche wiring harness adapters and crimped it onto the aftermarket head unit. Left everything else the way it was.
I did have to replace my speakers as the passenger's front one and the driver's rear were both blown out bad. But again, used the factory wiring. Just crimped new connectors on the speaker ends and called it good.
No offense, but unless you're going in to audio competitions where you're running several hundred watts into your door speakers, the factory wiring is going to be more than sufficient. 18/20 gauge wire will handle more than anything a standard head unit can put out. Really, why re-engineer something the factory already did for you? And since the factory amp is already there, why not make use of it?
I've got 50W Blaupunkt speakers in the front and 55W Pioneer speakers in the rear. I can take my head unit up to just before the distortion point and all the speakers handle it just fine. To the point that even screaming at each other you're not going to have a conversation. Just ain't happening. The stereo is too loud.
Add in the 160W home stereo sub in the back and there's no way in hell you're seeing anything out of any of the three mirrors. They're just a blur.
Oh, and none of my levels are cranked. Bass is 50%, treble is about 80% and the sub is at 50% (with the gain on the sub at 50% and crossover at 100Hz). Bass doubler setting is off as is Loudness.
________________
#4
Mickey_D is offline
post #13 of 13 Old 04-04-2013, 02:04 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
why run new wiring? because the factory wiring insulation is prone to becoming brittle and breaking on you.
