Advice for pulling the hood? - JeepForum.com
post #1 of 5 Old 06-27-2013, 04:19 AM Thread Starter
AVR2
I'm probably going to pull the hood to ease reinstallation of my cylinder head. Any advice for doing it on the 1993 ZJ? Looks like 3 nuts on each side, but any gotchas I should know about? Will the hood stay up by itself with all the nuts removed, or will it need to be supported once I start loosening them?
EDIT - my bad, I should have read the FSM properly and not just scanned it. I think I was looking at the nuts that hold the hinges to the body, when I should actually leave the hinges attached and unbolt the hood from the hinges - correct?
AVR2 is offline
post #2 of 5 Old 06-27-2013, 04:31 AM
ZeeJay1997
Yes, do not pull hinges.
Be sure to scribe the outline of the hinge onto the hood before you remove it.
This will prevent the *** pain of lining the hood up when you reinstall
ZeeJay1997 is offline
post #3 of 5 Old 06-27-2013, 04:43 AM Thread Starter
AVR2
Cool. Just to confirm, the hood doesn't need to be externally supported while I'm removing the nuts holding it to the hinges? I have visions of it pivoting forward off the hinges and landing on my head when the nuts are loosened.
AVR2 is offline
post #4 of 5 Old 06-27-2013, 04:46 AM
ZeeJay1997
You'll need some help, one person will suffice
post #5 of 5 Old 06-27-2013, 05:53 AM
AnotherRedZj
It can be done alone,(so I learned) as long as your tall enough to support the hood from the front and reach the last 2 nuts that you will need to leave loose. (ones closest to the windshield).
AnotherRedZj is offline
