-   -   Advice for pulling the hood? (http://www.jeepforum.com/forum/f13/advice-pulling-hood-1541922/)
AVR2 06-27-2013 05:19 AM
30 Attachment(s)
I'm probably going to pull the hood to ease reinstallation of my cylinder head. Any advice for doing it on the 1993 ZJ? Looks like 3 nuts on each side, but any gotchas I should know about? Will the hood stay up by itself with all the nuts removed, or will it need to be supported once I start loosening them?
EDIT - my bad, I should have read the FSM properly and not just scanned it. I think I was looking at the nuts that hold the hinges to the body, when I should actually leave the hinges attached and unbolt the hood from the hinges - correct?
ZeeJay1997 06-27-2013 05:31 AM
Yes, do not pull hinges.
Be sure to scribe the outline of the hinge onto the hood before you remove it.
This will prevent the *** pain of lining the hood up when you reinstall
AVR2 06-27-2013 05:43 AM
30 Attachment(s)
Cool. Just to confirm, the hood doesn't need to be externally supported while I'm removing the nuts holding it to the hinges? I have visions of it pivoting forward off the hinges and landing on my head when the nuts are loosened.
ZeeJay1997 06-27-2013 05:46 AM
You'll need some help, one person will suffice
AnotherRedZj 06-27-2013 06:53 AM
It can be done alone,(so I learned) as long as your tall enough to support the hood from the front and reach the last 2 nuts that you will need to leave loose. (ones closest to the windshield).
The time now is 10:35 PM.
