Advice on first ZJ!!! Help me please - Page 3 - JeepForum.com
post #31 of 34 Old 02-23-2012, 06:36 PM
pincheburro956
Originally Posted by BRae_in_a_ZJ View Post
what do you mean by i cant have it? like its physically impossible? or just not safe... because im sure i have one. i have serious tire rub too
ZJ, XJ, and WJ CANNOT have a body lift. impossible. the body/frame is one single unit. hence the term "unibody". only suspension lifts are possible.
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #32 of 34 Old 02-23-2012, 06:42 PM Thread Starter
BRae_in_a_ZJ
Originally Posted by Foundrydude View Post
A body lift is blocks between the frame and body.
A ZJ is a unibody, so the frame is welded directly to the body (simplified explanation), you can't unbolt the body and slide spacers between em.
Look on top of your springs. You're gonna see round, black blocks about two inches tall. That's your lift. It's called a budget boost. Some people might call them coil spacers.
Good luck with the truck
i undestand now thats exactly what i see. thanks for clarifying guys! makes much more sense now
'97 5.2 Laredo "Maggie"
BRae_in_a_ZJ is offline
post #33 of 34 Old 02-24-2012, 08:54 AM
Dluenz
If you have a 2" lift, and you probably do because thats usually what the BB's are you can only run 31's without rubbing too much, you either need more lift or less tire.
Dluenz is offline
post #34 of 34 Old 02-25-2012, 05:50 PM Thread Starter
BRae_in_a_ZJ
yeah my 32s rub in parking lots if i cut the wheel hard im thinking my next set will be 31s... i can get used to just being carefull though. thanks!
first jeep , tune up , zj
Advice!!! cherokeen ZJ Grand Cherokee Forum 2 10-22-2011 08:10 AM
ZJ ARB Advice RingRingRing ZJ Grand Cherokee Forum 5 01-23-2009 06:34 PM
Want to Buy 5.9, need advice djannello ZJ Grand Cherokee Forum 2 10-07-2008 08:53 AM
New 95 ZJ. Need some help/advice. Absath ZJ Grand Cherokee Forum 5 08-03-2005 05:39 PM
BB Doesn't fit on ZJ...Help/advice please GIBMAR ZJ Grand Cherokee Forum 7 05-27-2005 10:51 PM
