Advice on first ZJ!!! Help me please - Page 2 - JeepForum.com
post #16 of 34 Old 02-21-2012, 08:17 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by BRae_in_a_ZJ View Post
any advice will help! even the little things. thank you so much!
Welcome!
The best advice I can give you for a ZJ or anything else is to do it right the first time and never be in a hurry. You gotta realize if you buy an old ZJ you will always be working on it.
HighLonesome is online now
post #17 of 34 Old 02-21-2012, 08:22 PM
pincheburro956
get ready to "ignore" your VIC when it starts beeping and flashing all the crap that is wrong with your jeep, but still works.
dash lights will go out , or work when they want.
change out your lift supports on your rear hatch, and glass.
etc...., etc....., etc......
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline
post #18 of 34 Old 02-21-2012, 08:35 PM
jeepgoonie
2008 XK Commander
x5653
Just Empty Every Pocket
jeepgoonie is offline
post #19 of 34 Old 02-21-2012, 08:38 PM
Freestyle713
1994 ZJ
Originally Posted by HighLonesome View Post
Welcome!
x2 I cant tell you how many times I have worked on my exhaust and my door speakers. This past weekend, I was re-mounting my driver door speaker and I completely forgot to hook it up. Now I gotta go in there again and actually hook it up this time
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #20 of 34 Old 02-21-2012, 09:19 PM
ZJMTL
Be prepared to spend lots of time and money working on it! Just got my ZJ two weeks ago and haven't had a day when I haven't worked on her in some way or another. If you like to tinker and keep busy, perfect vehicle!!! I absolutely adore mine.
ZJMTL is offline
post #21 of 34 Old 02-21-2012, 09:54 PM
LouC
2007 WK
You know I have owned a 98 ZJ since new (now with 136000 miles) two years ago I bought an 07 WK Limited Hemi, but couldn't stand to sell the ZJ, so I kept it as a second vehicle, and use it all the time. I put a new radiator and water pump in it last year, have made some minor repairs over the years, but outside of the ac evaporator, the trans seals (got a Reman Mopar trans under my ext warr) it's been a reliable vehicle. Easy to fix, simple, always starts.
some tips....
Shocks, Bilstein HDs work great on ZJs
brake rotors, don't need fancy slotted or drilled, plain old Wagner full cast iron ones work fine.
ATF+4, nothing else in the auto trans
transfer case you can use ATF+4, or Dexron ( I used to use Mobil 1 Dexron in my Transfer case, but now use ATF+4 since it's synthetic
Syn 75-140 gear oils in the front and rear differentials, mine have held up great with this oil (including towing a 4000 lb boat)....
Exhaust system, a Dynomax cat back is a good low cost exhaust for a ZJ....
LouC is offline
post #22 of 34 Old 02-21-2012, 10:09 PM
ZJMTL
Don't expect better than 12 or 13mpg if you live in town, too.
ZJMTL is offline
post #23 of 34 Old 02-22-2012, 06:03 AM
zeejay92
Couldnt agree more
zeejay92 is offline
post #24 of 34 Old 02-22-2012, 03:33 PM
JohnnyZJ
just read your sig, and it says you have 32" BFGs and a 2" body?
might wanna swap that body lift out for a suspension lift. much safer.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #25 of 34 Old 02-22-2012, 04:00 PM Thread Starter
BRae_in_a_ZJ
Thanks so much everybody!!
'97 5.2 Laredo "Maggie"
BRae_in_a_ZJ is offline
post #26 of 34 Old 02-23-2012, 10:09 AM
Dluenz
You cant have a body lift on a ZJ. Its a unibody. I thought that a while ago when I had just gotten mine too so no worries!
Dluenz is offline
post #27 of 34 Old 02-23-2012, 06:24 PM Thread Starter
BRae_in_a_ZJ
what do you mean by i cant have it? like its physically impossible? or just not safe... because im sure i have one. i have serious tire rub too
post #28 of 34 Old 02-23-2012, 06:28 PM
Jeepfordan
Physically impossible
1998 XJ- 4.0/AX-15/231- 3.5" RE. 4.10 gears - 4.6 build in progress.
Jeepfordan is offline
post #29 of 34 Old 02-23-2012, 06:35 PM Thread Starter
BRae_in_a_ZJ
im a little confused. i have receipts and everything and i think i can see it on the rear. and it definitely sits above stock. is there a way they could have boosted it using coil spacers? also for the record the previous owner had cut and trimmed all fenders to make room for tires (but they still rub on hard cut parking lot type turns)
post #30 of 34 Old 02-23-2012, 06:36 PM
Foundrydude
A body lift is blocks between the frame and body.
A ZJ is a unibody, so the frame is welded directly to the body (simplified explanation), you can't unbolt the body and slide spacers between em.
Look on top of your springs. You're gonna see round, black blocks about two inches tall. That's your lift. It's called a budget boost. Some people might call them coil spacers.
Good luck with the truck
Foundrydude is offline
first jeep , tune up , zj
Advice!!! cherokeen ZJ Grand Cherokee Forum 2 10-22-2011 08:10 AM
ZJ ARB Advice RingRingRing ZJ Grand Cherokee Forum 5 01-23-2009 06:34 PM
Want to Buy 5.9, need advice djannello ZJ Grand Cherokee Forum 2 10-07-2008 08:53 AM
New 95 ZJ. Need some help/advice. Absath ZJ Grand Cherokee Forum 5 08-03-2005 05:39 PM
BB Doesn't fit on ZJ...Help/advice please GIBMAR ZJ Grand Cherokee Forum 7 05-27-2005 10:51 PM
