Advice on first ZJ!!! Help me please - JeepForum.com
post #1 of 34 Old 02-21-2012, 01:03 PM Thread Starter
BRae_in_a_ZJ
today i will be taking home my first ZJ! i am excited but i really have a few concerns.
what are some problems i should look out for?
is there anything i need to check for?
how can i get this jeep in ship shape before my inspection?
any advice will help! even the little things. thank you so much!
'97 5.2 Laredo "Maggie"
BRae_in_a_ZJ is offline
post #2 of 34 Old 02-21-2012, 01:15 PM
Oldfrog
2007 WK
-If it's a 97 with a 4.0 in it, go ahead and plan to spend $249 on a rebuilt PCM when it begins stalling in the middle of busy intersections during rush hour.
- Make sure the front trac bar bolts are tight. ( death wobble)
- When your front passenger side carpet gets wet while running the air, search for the drain clean out procedure here on the forums.
- Keep your battery terminals clean and tight ! This is especially important on Jeeps.
- You headliner is going to fall down. Deal with it and get it replaced. ( $160)
- Now, go run over some Toyotas !
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 34 Old 02-21-2012, 01:18 PM
gactech
Don't complain about the MPG
gactech is offline
post #4 of 34 Old 02-21-2012, 01:25 PM
zeejay92
Change your crankshaft sensor along with 2 rapid oil changes @500 miles a piece, transmission fluid (ATF-4 from dealer i suggest), transfer case fluid (from dealer also) and front and rear axle fluid (80w-90 for most). This is what I did on mine and no major problems thus far. Good luck with it!
zeejay92 is offline
post #5 of 34 Old 02-21-2012, 01:30 PM
Freestyle713
1994 ZJ
x3829
And you have the nv249 transfer case, which means its in 4wd all the time, and if it hasnt already, the vc will fail sooner or later. Since you have a 97, you can find a 242 or 231 out of a 4.0 and swap it in directly if you find one with the right input shaft length. This way you have 2wd. Also, if you plan on lifting it, plan on swapping out the cv joint in the front driveshaft as well, because that is notorious for failing once you lift it.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #6 of 34 Old 02-21-2012, 01:58 PM
ngould1
Be ready to replace muffler and catalytic converter. Shocks are probably shot. My shocks had holes in them from rusting out. And possible steering linkage like sway bar links tie rod ends things like that. Good luck!
ngould1 is offline
post #7 of 34 Old 02-21-2012, 02:19 PM
gactech
But even though all of this has been said it really is a great vehicle.
gactech is offline
post #8 of 34 Old 02-21-2012, 02:27 PM
accord23
Enjoy your Jeep!!! Suck a great toy..
accord23 is offline
post #9 of 34 Old 02-21-2012, 02:36 PM
Ket72
I guess the number 1 thing is get ready to spend alot of time at your closest auto parts store.
Ket72 is offline
post #10 of 34 Old 02-21-2012, 04:03 PM
hdrocknroll
Change all fluids ,Ft&RR Dif,Transfer (Case ATF+4),(Trans+ filterATF+4),Power Steering,Coolant,Oil,
New Air filter.Put some seafoam in your gas tank,right off the bat.
If you have a oil leak by the oil filter it is the, oil filter adapter O rings, 5 bucks at dealer.
I could make this list very long but wont.
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #11 of 34 Old 02-21-2012, 04:46 PM
Foundrydude
Since your jeep isn't stock, the previous owner has probably addressed some common concerns. It's really hard to say what it's going to need. Make sure all the lights work and nothing obvious is wrong and run it thru the inspection station. Go from there.
Good luck with it, always exciting to have a new vehicle.
Foundrydude is offline
post #12 of 34 Old 02-21-2012, 08:07 PM Thread Starter
BRae_in_a_ZJ
I will make sure to do these things. good news for me the previous owner just put in brand new headliner. i will make sure to run over as many yotas as i can
post #13 of 34 Old 02-21-2012, 08:08 PM Thread Starter
BRae_in_a_ZJ
Thanks for the pointers! i will get as much done as i can with the fluids thats always a good idea
post #14 of 34 Old 02-21-2012, 08:10 PM Thread Starter
BRae_in_a_ZJ
its funny you said that cuz my shocks are obliverated haha thanks for the pointers!
post #15 of 34 Old 02-21-2012, 08:12 PM Thread Starter
BRae_in_a_ZJ
thanks so much everybody! i already have my list of things to replace/refresh started thanks to this.
first jeep , tune up , zj
Advice!!! cherokeen ZJ Grand Cherokee Forum 2 10-22-2011 08:10 AM
ZJ ARB Advice RingRingRing ZJ Grand Cherokee Forum 5 01-23-2009 06:34 PM
Want to Buy 5.9, need advice djannello ZJ Grand Cherokee Forum 2 10-07-2008 08:53 AM
New 95 ZJ. Need some help/advice. Absath ZJ Grand Cherokee Forum 5 08-03-2005 05:39 PM
BB Doesn't fit on ZJ...Help/advice please GIBMAR ZJ Grand Cherokee Forum 7 05-27-2005 10:51 PM
