Adustable Track Bar Install info - JeepForum.com
post #1 of 7 Old 08-25-2012, 08:04 AM Thread Starter
singleytools
I have a '98 GC with a 3" lift. I've been trying to get rid of severe DW. Replaced TB, Drag link tie rod end, aligned, advanced tire balance and still had severe DW. Have "tracked" down to TB (again) so I just ordered an adjustable Rubicon RE1600.
My question is what alignment specs are the best for this set-up. Thanks guys...
singleytools is offline
post #2 of 7 Old 08-25-2012, 08:29 AM
PolkaPower
What ever makes the axle look like it's centered. Unbolt the TB and use the steering wheel to move the body over the axle until it looks centered then bolt it up. Or you can bounce up and down on the front and shake it side to side and let it settle where it wants. Make sure you are on level ground.
PolkaPower is online now
post #3 of 7 Old 08-25-2012, 08:29 AM
sskilla
i apologize, but exactly do you mean by, "alignment specs"?
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #4 of 7 Old 08-25-2012, 08:41 AM
newfieZJ
@3" , stock specs would apply .
What's all done to your jeep , springs or spacers for your 3"s . Any lower control arms ? Did you do the shocks also ?
newfieZJ is offline
post #5 of 7 Old 08-25-2012, 09:00 AM Thread Starter
singleytools
Alignment specs: Toe-in, caster, camber. You know, alignment specifications with a 3" lift.
post #6 of 7 Old 08-25-2012, 09:09 AM Thread Starter
singleytools
Spring, shocks, contorl arms. What I did was swap an existing 3" lift off of my '93 ZJ to a '98 ZJ. The one thing I wasn't sure of was if there was an adjustable TB or drop-down bracket on my '93 that wasn't swapped. The '93 is sold and I have been left with a DW from hell. Have to clean the seats every time it happens. Replaced the stock TB with little difference and I'm now going to an adjustable Rubicon and I understand there is no need for a drop-down bracket... I don't have an off-road shop nearby so I'm hoping to give my alignment shop some extra info from you guys.
post #7 of 7 Old 08-25-2012, 09:19 AM
sskilla
toe-in is always 1/8 - 1/16th toed in.
i believe castor is +- 4 - 7 degrees. trying to match on each side.
camber is not adjustable on a zj
when you installed your new CA's did you torque the bolts at ride height?
sskilla is offline
3" lift , alignment , death wobble
rear track bar install help ksturgio ZJ Grand Cherokee Forum 1 07-25-2010 02:27 PM
WJ track bar install tips silver_laredoSE ZJ Grand Cherokee Forum 3 10-04-2009 10:31 AM
install help, track bar question 98ZJluke ZJ Grand Cherokee Forum 2 04-04-2009 01:54 PM
Track Bar install 97GRANDCRASHOKE ZJ Grand Cherokee Forum 3 05-30-2007 06:06 PM
What are some good quality/budget track bars and arms? Also I need lift info. bjl95mustang ZJ Grand Cherokee Forum 3 10-21-2006 10:34 PM
