Adjustable Trackbar - JeepForum.com
post #1 of 2 Old 11-19-2003, 03:04 PM Thread Starter
jjacquez
Adjustable Trackbar
What is the purpose of the adjustable tarck bar??
What is its function??
Thanks for your assistance
jjacquez is offline
post #2 of 2 Old 11-23-2003, 11:46 PM
Swamp Boy
Swamp Boy's Avatar
To recenter the axle after a lift..
When you lift it changes the dynamics of the vehicle.. Since the track bar is mounted to the frame on one side when you lift it will pull the axle to that side. An adjustable track bar will push it back in place.. And it is good for your next lift to if you are lucky..
That is why you buy adjustable instead of fixed length . Because you can use the adjustable with the next lift where a fixed length would again be worthless when you go higher..
Hope that helps..
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
JKS adjustable front trackbar or IRO Double shear conversion kit? Travis873o ZJ Grand Cherokee Forum 3 08-26-2009 11:51 AM
Lift completed, Adjustable Trackbar needed ASAP SDT03GCOverland ZJ Grand Cherokee Forum 8 08-10-2009 11:46 PM
Adjustable Trackbar ben_wagner ZJ Grand Cherokee Forum 1 04-22-2006 01:02 AM
Which adjustable trackbar to get? JCDubya ZJ Grand Cherokee Forum 18 02-21-2006 10:27 PM
Adjustable Trackbar Questions jnkarrik ZJ Grand Cherokee Forum 10 01-24-2005 06:01 PM
