Adjustable control arms on stock height zj - JeepForum.com
post #1 of 8 Old 08-16-2009, 05:24 PM Thread Starter
kmk108
I need to take my 3.5 in lift off my zj. I got a set of control arms from IRO that are all adjustable. If I kept the control arms on and lowered the jeep back to stock height, will the arms be able to be adjusted to near stock length, or will they be too long and screw with the alignment?
30 BFG A/T, Flowmaster Super40, Alpine head unit, Alpine amp, Rockford speakers, Sony subs, cobra cb
White Jeep Club Member #108
2009 FA CUP CHAMPIONS
CAREFREE, WHEREVER WE MAY BE
WE ARE THE FAMOUS CFC
AND WE DON'T GIVE A F@#K
WHOEVER YOU MAY BE
CUZ WE ARE THE FAMOUS CFC
kmk108 is offline
post #2 of 8 Old 08-16-2009, 06:22 PM
newfieZJ
stock lowers are 15.75 on the frt and 17 on the rear IIRC eye to eye . I can't find an old post where I accually measured them . Can't see why it wouldn't work , alignments are adjustable
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 8 Old 08-16-2009, 06:27 PM
Jones
Consider the following...
Jones's Avatar
Why do you need to take the lift off and then put the control arms on? Why not keep it at the same height and add the control arms to your current set up?
Jones is offline
post #4 of 8 Old 08-16-2009, 06:32 PM
leofanti
i dont believe he is removing his lift and putting on adjustable control arms, i believe everything is already installed, and he just wants to know when he removes his lift if he can just leave the c-arms on. now my opinion would be, no, you should just send your lift and c arms to me and i can utilize them here in arizona, or you could pull one of the adjustables out, and see how much adjustment there is. if it can be made the same length as stock, well they should work. now, i have seen stock length adjustable control arms, and i have seen long arm adjustable ones. it really just boils down to what can the adjustables do.
leofanti is offline
post #5 of 8 Old 08-16-2009, 08:26 PM Thread Starter
kmk108
^ yea thats what i meant. I could have sworn that when I put them on, i compared the arms and they could be adjusted to be the same length.
WHOEVER YOU MAY BE
kmk108 is offline
post #6 of 8 Old 08-16-2009, 09:43 PM
crazydude2500
here is what you do...pull them off ship them to me and ill send you my stock ones...haha j/k i dont think it would mess with the alignment...but it might push the axel forward more...do as said above take one off adjust it all the way down...and compare it to your stocker if you still have them....
pat
green lifted 4.5 w/32's custom front bumper 5.2L
97 xj stock blue tow hooks F&R 4.0L
2004 dodge neon SRT-4
crazydude2500 is offline
post #7 of 8 Old 08-16-2009, 09:57 PM
Jones
Jones's Avatar
FYI - I Just looked through the FAQ and didn't see anything on control arms.
Jones is offline
post #8 of 8 Old 08-17-2009, 07:17 AM
Yardman Harry
O
Yardman Harry's Avatar
You will be fine. When I put my adjustables on i started them off at stock length... i had the adj next to the stock ca and they were the same length.
But you have to tell us... why are you removing the lift?
I have some stock cas that you could have, you just pay for the shipping
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
adjustable control arms lateralus3 ZJ Grand Cherokee Forum 23 01-19-2010 06:02 PM
adjustable control arms on 3.5" short arms (ride quality) 3xX ZJ Grand Cherokee Forum 7 11-29-2009 12:16 PM
IRO Adjustable control arms mk07138 ZJ Grand Cherokee Forum 13 05-30-2007 04:59 AM
Adjustable Track Bar at Stock Height? Upside ZJ Grand Cherokee Forum 2 01-20-2007 11:30 AM
Adjustable track bar at stock height? askoop ZJ Grand Cherokee Forum 1 04-03-2006 01:54 PM
