Adjustable brake/gas pedals - JeepForum.com
post #1 of 10 Old 02-14-2010, 04:42 PM Thread Starter
ncr8081
2004 XJ Cherokee
I have a 2004 Grand Cherokee Ltd with adjustable pedals - the pedals only move a 16th of an inch -- i thought that this was the way it was designed and thought that it was pretty lame. However, at an oil change the attendant adjusted the pedal all the way up about 2 to 3 inches up. the gas pedal stayed on the floor. Now the pedal will not go back to the original position. after looking at the assembly it appears that the gas is all the way down and the brake is all the way up. I think that because of this the system is bound -- does anyone know how to disconnect the slave cable from the brake pedal to the gas pedal with out destroying the system?
I just disconnected the slave cable -- the cable is held in by fitting that i have no idea what the name is but you will have to get a narrow pliers to squeeze the bottom of the fitting then pull the cable out. By the way the silver part will turn some so that you can get a better angle. My theory was that if i could get this disconnected the brake pedal would then move -- but i was wrong. HELP ME!!!!!
ncr8081 is offline
post #2 of 10 Old 02-14-2010, 05:25 PM
Apollo21
mine is stuck the same way i haven't found a way to fix it yet
Midshipmen Patrick 1/C USMMA DD: 2004 Golf GLS TDI 43mpg and 2002 Overland: Zone 4in, 32in Treadwright MTRs, IRO upper CAs, lift gate light mod, Alpine/Polk speakers, and power inverter with USB in dash mod, CB, custom rear swing out tire carrier Build thread
SOLD
Apollo21 is offline
post #3 of 10 Old 02-14-2010, 06:54 PM
Falkon
Here is a thread where this problem was resolved...
http://www.jeepsunlimited.com/forums...=adjust+pedals
Falkon is offline
post #4 of 10 Old 02-14-2010, 08:45 PM Thread Starter
ncr8081
2004 XJ Cherokee
I just did that -- it did not work for me.
ncr8081 is offline
post #5 of 10 Old 02-15-2010, 07:41 AM
Apollo21
i'm gonna try that
SOLD
Apollo21 is offline
post #6 of 10 Old 02-15-2010, 08:57 AM
trailblaze
trailblaze's Avatar
this is the thing about having more "junk" (accessories) to go bad.... i have these pedals too and NEVER have adjusted them
Matt
trailblaze is offline
post #7 of 10 Old 02-15-2010, 09:03 AM Thread Starter
ncr8081
2004 XJ Cherokee
no kidding. I did not adjust mine either but the Oil Change guy did now the brake pedal is up to my chest and the gas pedal is on the floor. I removed the slave cable but it did not unlock the Brake pedal still in my chest. -- Think i should wack it with a hammer?
ncr8081 is offline
post #8 of 10 Old 02-15-2010, 11:23 AM
trailblaze
trailblaze's Avatar
hahahaha.... whacking it with a hammer!!!
Matt
post #9 of 10 Old 02-16-2010, 08:45 AM Thread Starter
ncr8081
2004 XJ Cherokee
Well I didn't whack it with a hammer but, it did finaly allow me to adjust the pedal down about half way --- much better than it was. When it was adjusted all the way up it was dangerious. I would have to pull my foot all the way up, hitting the steering wheel with my knee, to apply the brakes. Thank goodness I did not have an emergency while it was up. Now I will keep pushing the button to get it further down -- when it is fixed I will un plug the power to the motor. Note: it is extremely hard to get a plier on the fitting unless you turn the silver end around a little so you can get at it.
ncr8081 is offline
post #10 of 10 Old 02-16-2010, 10:01 AM
LordHobbit
I'd go hit the oil change guy with a hammer.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
adjusting , breaks , gas pedal
Adjustable pedals Issue, Brake Stuck ! mgtrader WJ Grand Cherokee Forum 8 10-17-2011 10:11 AM
Broken Adjustable Pedals nierace WJ Grand Cherokee Forum 8 12-22-2010 06:22 PM
Adjustable brake pedals broken...Need help on fix/parts Billyray WJ Grand Cherokee Forum 5 04-11-2010 07:24 PM
First post - question about adjustable pedals Mandres ZJ Grand Cherokee Forum 2 02-14-2009 03:26 PM
WJ pedals,are they the same as the WK ??? jeepster2000 ZJ Grand Cherokee Forum 6 08-24-2008 02:30 PM
