adjust shifter linkage - JeepForum.com
post #1 of 4 Old 10-22-2013, 08:59 PM Thread Starter
davidtownsend
2006 WK
When I need to shift into any position I have to go one down then back up. Like I have to put out in second and our will shift into drive. Then I can put out into drive and it'll stay. This happened after I swapped transmissions. Any help would be appreciated!
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #2 of 4 Old 10-22-2013, 09:02 PM Thread Starter
davidtownsend
2006 WK
I've tried to loosen the bolt that is on the transmission and adjust it. But to no effect.
post #3 of 4 Old 10-23-2013, 01:18 AM
Rich93ZJ
From FSM
Shift linkage adjustment is important because it
positions the valve body manual valve. Incorrect adjustment
will cause creeping in Neutral, premature
clutch wear, delayed engagement in any gear, or a
no-start in Park or Neutral position.
(1) Shift transmission into Park.
(2) Raise vehicle.
(3) Release cable adjuster clamp (at transmission
end of cable) to unlock cable .
(4) Unsnap cable from cable bracket (SKIP THIS).
(5) Check transmission shift lever position by moving
it all the way rearward into Park detent.
(6) Verify positive engagement of park lock by attempting
to rotate propeller shaft. Shaft will not rotate
when park lock is engaged.
(7) Snap cable into cable bracket on transmission (SKIP THIS).
(8) Lock shift cable by pressing cable adjuster clamp
down until it snaps into place.
(9) Check engine starting. Engine should start only
in Park and Neutral.
(10) Lower vehicle.
93 ZJ 5.2V8 3.5 iro 31x10.5
08 Silverado 6in lift 35's
Rich93ZJ is offline
post #4 of 4 Old 10-23-2013, 08:38 AM Thread Starter
davidtownsend
2006 WK
Originally Posted by Rich93ZJ View Post
From FSM
(2) Raise vehicle.
(10) Lower vehicle.
Thank you so much!
