Adding Remote Start to a WJ - JeepForum.com
post #1 of 12 Old 06-26-2008, 02:49 PM Thread Starter
FooK
FooK's Avatar
Okay, here goes...
I have a 2002 Jeep Grand Cherokee Limited 4.7L Quadradrive.
I want to add remote start to it. I'd like to do it as cheaply as possible, and I don't really care about gaining alarm features.
That said, I'd really rather not have two remotes to use, because I have my keyless entry too.
How should I go about it?
Jason Roy - Marketing Director at WP
Driver #1724 Team WP Jeepspeed
Co-Driver #36 ERS Rally Team
FooK is offline
post #2 of 12 Old 06-26-2008, 03:06 PM
Windowsrookie
I'd go with any made by Directed Electronics.
http://www.directed.com/Products/Security/Default.aspx
They are very difficult to install on your own though, requires splicing into factory wires.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #3 of 12 Old 06-26-2008, 03:10 PM
-Shoey-
2010 KK Liberty
A warning, mine had one at one point or the other, and someone removed it. However, they didn't remove all of it, or messed up when it was installed, because there is a wire from it that leads to the #3 injector, and somehow this shorted something or something (really not sure) but now I need a new PCM because of it.
2010 KK Renegade
USN Jeep Club #115
-Shoey- is offline
post #4 of 12 Old 06-26-2008, 03:31 PM Thread Starter
FooK
FooK's Avatar
Installation is no issue. I have a friend that does that kinda junk all the time.
FooK is offline
post #5 of 12 Old 06-26-2008, 04:12 PM
painted600rr
wj catching on fire in 5. 4. 3. 2. 1
painted600rr is offline
post #6 of 12 Old 06-26-2008, 04:13 PM Thread Starter
FooK
FooK's Avatar
Thanks for the useful post.
FooK is offline
post #7 of 12 Old 06-26-2008, 04:46 PM
gcjeeping
gcjeeping's Avatar
I paid 60 something bucks for mine on ebay 7 years ago and its still working. It has 2 lcd 2way paging remote starts, glass tamper, 2 window kits, sonic something. I got the DEI key bypass (10 bucks ebay) and their alarm bypass (20 bucks ebay). With this setup I only have 1 remote that still activates all the originals functions and starts the jeep. It was easy to hook up except the wording for the DEI and remote start were worded a little different. I called the remote start hotline and they talked me through the 2 wires I was unsure about. Put it in on a sat, about 6 hours. A couple posts up the guy was talking about a wire to the injector. The kit I got had the option for current sensing or plug firing to detect engine run. Plug sensing requires you to hook a wire to an injector. I didnt do that part and it worked fine. I only had to splice into the start/acc wires under the dash and the break pedal switch. Other than that the alarm bypass hooked 1 wire up to the back of the computer test port by the driver left kick panel. Love my remote and has great range. Like I said it only uses the remote start to do all the original functions and the original remote still works too.
Good luck.
Also if you do a search on here and JU you will find several post on the subject.
_____________
gcjeeping is offline
post #8 of 12 Old 06-26-2008, 04:54 PM Thread Starter
FooK
FooK's Avatar
Good luck.
Awesome do you have any links to examples of what you bought?
FooK is offline
post #9 of 12 Old 06-26-2008, 08:10 PM
gcjeeping
gcjeeping's Avatar
Remote Starter. This is the closest one I can find to mine.
http://cgi.ebay.com/ebaymotors/FM-2-...spagenameZWDVW
This is the key bypass. If you have two keys great, if you have one you still can make it work. I only have one. I got a plain blank cut and put the real chip key in the unit. After the jeep starts I put the copy key in and turn it 2 clicks (just before start). and step on the brake and everything is normal like the chipped key is in the ign.
http://cgi.ebay.com/ebaymotors/NEW-D...em200233367601
This is the data bus module
http://cgi.ebay.com/Directed-DEI-Jee...QQcmdZViewItem
_____________
post #10 of 12 Old 10-01-2009, 05:36 PM
JAC1502
Do you know which ignition constant positive wire is on the 40amp fuse? Red or pink/black?
#1 1997 Jeep TJ HEMI, 6" lift springs, 2" body lift, semi long control arms front and rear, Adjustable front and rear track bars, Slip-Yoke elim, 8.8 locked, 10,000 winch, Tube bumpers and rocker guards, Light bar, Custom swing away tire carrier, CAI, Electric cooling fans, Custom exhaust, Mickey T 35*14.5 on 15*12 wheels #2 2004 Grand Cherokee SE 4.0L, header, full exhaust, CAI, Bored TB, Clarion 10, RC X series 4" + 1, teflon wheels 17s, roof rack, winch, etc.
JAC1502 is offline
post #11 of 12 Old 10-01-2009, 09:29 PM
mosespaul
Sorry for the late chime in......
Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers for your wiring needs.
Stereo, Alarm, Remote Starter, Cruise Control, Navigation Wiring
DO NOT MINDLESSLY FOLLOW.(always double check)
This will help make testing the correct wires faster.
This was a tach wire ( some hook to tach some hook to injector to get a pulse to make sure the engine is running...called Tach mode.)
You will need a door lock module and follow the second link to get factory disarm wires location and re-arm wires as well (so you can use one remote)
Good luck
mosespaul is offline
post #12 of 12 Old 10-01-2009, 09:34 PM
WiCkeDuDe
WiCkeDuDe's Avatar
I bought two DEI alarms, I think they were both remote start - python 680xp and viper 791xv. I installed both at least 5 years ago with the passkey modules for the keys needed. Never had a problem with either.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
Whats more efficient, a new factory remote or a remote start system? compcrasher86 ZJ Grand Cherokee Forum 7 01-06-2009 05:13 PM
Adding Remote Start to 07 GC 4.7 nickm1024 WK Grand Cherokee & XK Commander Forum 1 12-01-2008 07:19 PM
Diesel WK: Adding remote start to an '07 bobholthaus WK Grand Cherokee & XK Commander Forum 23 01-18-2008 09:56 PM
Remote Start ItalianJeeper77 WK Grand Cherokee & XK Commander Forum 7 12-13-2007 09:10 AM
Remote start avsman5 ZJ Grand Cherokee Forum 5 08-31-2004 09:50 PM
