adding fog lights - JeepForum.com
post #1 of 8 Old 12-02-2008, 08:21 PM Thread Starter
ktplotts
adding fog lights
My jeep (02) didn't come with fog lights, and i want to add them. I would really like to use stock housing, so that there is a good fit in the opening. How do stock fog lights mount to the bumper? Is there a wiring harness that i can tap into somewhere or should i just make my own and put a manual switch inside the jeep?
Anyone have any suggestions/comments/thoughts?
I am open to some ideas and am just lost right now and thanks for the help.
-Kevin
ktplotts is offline
post #2 of 8 Old 12-02-2008, 08:36 PM
madrabbitt
madrabbitt's Avatar
my 99 has the wiring in the harness, but didnt come with them stock.
they sell mopar kits that are the light, the relay, and the new control stalk, and you just install them.
Of course, you'd have to cut away the plastic in the bumper as well.
On that thought, Hella FF300's are a pretty good fit in the hole, and are 100 times better then stock.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #3 of 8 Old 12-02-2008, 09:12 PM Thread Starter
ktplotts
I like that idea. I had looked into mopar ones, but they are way too much money and work for what I get out of those lights.
I am trying to make up my mind wether to go with the driving style or fog style. Do you know if the driving style will actualy out perform the low beam head lights.
Thanks,
Kevin
ktplotts is offline
post #4 of 8 Old 12-02-2008, 10:14 PM
madrabbitt
madrabbitt's Avatar
depends on the brand and quality.
If you get the driving beam versions of the ones i have, then yeah, they outshine the lows.
I have fog pattern, to fill in under where the low beams are
post #5 of 8 Old 12-09-2008, 05:37 PM
SET2JET
my 99 also has the wires in the harness, i have installed a fog light ready bumper cover and fog lights... but i would like to know if i can just change the headlight switch and add a relay and be good to go??? i have searched and i see alot of people wanting to do the same thing but i have not seen anybody that has done it... is it possable
SET2JET is offline
post #6 of 8 Old 12-09-2008, 06:04 PM
madrabbitt
madrabbitt's Avatar
Yes, you change the stalk to the correct one, add the relay in the PDC, and you should be good.
post #7 of 8 Old 12-09-2008, 06:21 PM
kjcdc090385
and if anyone needs the stalk or wires...I have them
kjcdc090385 is offline
post #8 of 8 Old 11-09-2009, 09:33 AM
BrittoJeep
So how hard is it to replace the control stalk? Do i need to take apart the steering column?
BrittoJeep is offline
(ZJ) Adding factory fog lights - how to ZJunk ZJ Grand Cherokee Forum 102 01-20-2015 11:33 PM
Adding fogs lights to 08, need help ecocav WK Grand Cherokee & XK Commander Forum 14 02-27-2009 03:47 AM
1999 Grand Cherokee adding fog lights jm2hayes ZJ Grand Cherokee Forum 2 01-16-2007 11:10 PM
Adding Fog lights to 98 ZJ njrealtor55 ZJ Grand Cherokee Forum 1 04-13-2004 03:43 PM
