Adding a digital vic? - Page 3 - JeepForum.com
post #31 of 46 Old 07-12-2013, 10:38 AM
zjosh93
Mine's the original 93 VIC, still works perfectly. Tells me the washer fluid is low and I check, it is and I add some. Tells me the brake light is out and I find a bad bulb. Tells me the oil is low and sure enough it's right below the fill line. The only thing it ever has done was completely die about six months ago. Took it apart and found a bad capacitor. Soldered a new one in and it's been working fine.
zjosh93 is offline
post #32 of 46 Old 07-12-2013, 03:35 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Xcaliber, hook up with a fsm for a 93 for a wiring diagram. I'm not familiar with earlier versions of the vic, but a 98 recieves the open door signals from the switch via the ccd bus /bcm.
Originally Posted by HighLonesome
coralman is offline
post #33 of 46 Old 07-12-2013, 05:46 PM
Lakoswolf
The only issue I've had with the VIC in either 93' I've owned is a bad oil level sensor which I shut up with a resistor, but otherwise it has worked flawlessly. Which is especially nice considering I had to refill my antifreeze for a good month repeatedly on the count of a bad water pump.
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #34 of 46 Old 07-17-2013, 11:58 AM Thread Starter
xcaliber81
Hooked up the LOM and I put the vic in and I noticed umong other thing it said I had a rear lamp failure are the pinnouts different if theres no vic? I have no burnt bulbs.
xcaliber81 is offline
post #35 of 46 Old 07-17-2013, 12:03 PM
leftfield6
Where are my damn keys?
leftfield6's Avatar
Sure about that? It will give you the RLF if your rear side marker lights are burnt out. Easy to overlook those tiny bulbs.
Jeepless for now, probably not for long
(former)
98 Grand Cherokee Limited 5.9
98 Grand Cherokee Laredo
77 CJ-5
75 CJ-5
leftfield6 is offline
post #36 of 46 Old 07-17-2013, 12:14 PM Thread Starter
xcaliber81
Oh for sure I checked everything lol took a brick to the brake peddal turned the four ways on as well as the parking lamps and everything lit up.
post #37 of 46 Old 08-03-2013, 11:15 PM
unabashedpraise
I blame this thread. Randomly the vic said there was a brake lamp failure. But there isn't.. hhhhhhhhh....
1998 Grand Cherokee Limited; 5.2 L, 249
Help: Rear left lock doesn't lock using power locks, but will unlock. Any ideas?
unabashedpraise is offline
post #38 of 46 Old 08-05-2013, 08:31 AM
exmilitary
I would clean the brake light contacts on the truck side. I did find corrosion on the contacts and that changes the resistance values for the vic console, and thus fixing the error massage.
exmilitary is offline
post #39 of 46 Old 08-05-2013, 08:51 AM
fljeepney
I just got mine working in my 5.9.Found out it was a fuse after 3 weeks of ownership.Wasn't really concerned at it,but I'm on vacation this week and needed something to do.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
1985 Corolla AE86 coupe
fljeepney is offline
post #40 of 46 Old 08-06-2013, 11:29 PM Thread Starter
xcaliber81
Lol so upon replacing my broken tail light i discovered i do have a burnt out tail light so it was telling the truth.
post #41 of 46 Old 08-12-2013, 06:47 PM Thread Starter
xcaliber81
so I changed the bulb and i put in the vic to see if rear lamp failure went out however it did not. Also it told me to check engine oil level but the thing is its actually low how does it know this I've never hooked up any sensors for that?
post #42 of 46 Old 08-12-2013, 07:27 PM
coralman
coralman's Avatar
Check to see if there is a sensor in the oilpan. If not it may be a default responce.
coralman is offline
post #43 of 46 Old 08-12-2013, 07:37 PM Thread Starter
xcaliber81
I know for sure there's no sensor in the oil pan ok then ill throw that out as a default response then.
post #44 of 46 Old 08-13-2013, 04:07 AM
coralman
coralman's Avatar
It was on some early jeeps, I can;t remember what years.
coralman is offline
post #45 of 46 Old 08-13-2013, 07:51 AM
zjosh93
My 93 has the oil level sensor. RockAuto sells the oil pan with the sensor hole and the sensor: if you have the pigtail hanging there you could easily add that sensor.
zjosh93 is offline
