-   -   Adding an auto dim sideview? (http://www.jeepforum.com/forum/f13/adding-auto-dim-sideview-1503045/)
OverlandZJ 04-02-2013 03:55 PM
I tried a search but not finding what i need.
Found a working Niner auto dim sideview i'd like to swap into my 98 Laredo... whats involved? Being that i have a 98 is the wiring there? Will i need a harness section from donor rig?
Is this controled via BCM and i'm SOL?
KoreaZJ 04-02-2013 06:56 PM
Outside mirror is controlled by auto day/night rear view mirror, that's where the sensors are. The back-up lamp input disables dimming while in reverse gear.
Need auto day/night rear view mirror/wiring, and two wires (YL/BK and YL/WT) between rear view and outside for auto dim outside to work.
Auto dimming rear view mirror connector...
http://i49.tinypic.com/r8rwpg.png
Driver side outside auto dim connector in door...
http://i49.tinypic.com/fwnkh0.png
xcaliber81 04-02-2013 07:00 PM
what about for a 94 is it the same deal my mirrors need replacing and was wondering about the auto dim setup.
Primordial 04-02-2013 07:07 PM
X2 but a 95 here. I'm installing a 96+ auto dim rear view so that part has the right connector. Could I just get the auto dim side mirror and wire it up? Granted I'm thinking of ditching the stock style mirrors altogether and going with something I can fold in while on the trail...but if I can do auto dim that may change my mind.
Sorry to jack your thread...
xcaliber81 04-02-2013 07:12 PM
I jacked it first lol.
KoreaZJ 04-02-2013 07:33 PM
For 93-95... no auto dim outside mirror and auto day/night rear view has a 3-pin connector.
Should be able to rewire to make 96+ mirror work with 93-95 door switches. Will only have manual positioning with no feedback/memory.
For auto dim to work, would need 96+ auto day/night rear view mirror, add two wires (for outside auto-dim) between rear view and outside auto dim mirror.
xcaliber81 04-02-2013 07:42 PM
so with the 96+ mirrors we would be able to adjust with the switch still? just the memory would not work correct?
KoreaZJ 04-02-2013 07:56 PM
All mirrors have simple reversible motors, no brains. They don't know if +12v/GND comes from 93-95 discreet switches or 96+ door modules.
Primordial 04-03-2013 12:01 AM
That's exactly what I'm doing for the rear view mirror. I was just going to use the 3 wires (my ZJ didn't come with anything auto dim) but it would be just as easy to run 2 more wires...
OverlandZJ 04-03-2013 08:24 AM
Korea...Thank You Sir.
I swapped out my OEM rearview with a Gentex177 autodim from a 97 Tahoe, this also has the Temp/Compass. It's leftover from my XJ.
Now that i know it's powered off the rearview i can make it work.
Thanks..
coralman 04-03-2013 05:20 PM
Thats a nice mirror Overland, was looking at them on ebay.
OverlandZJ 09-12-2013 12:59 PM
Bringing this back since the last mirror I found wasn't off a Niner or autodim afterall..
Guy is parting a 98 Limited, is there a way to ID an autodim? Extra wiring or something? IIRC these were 97-98 option only?
Is Korea ^^ still MIA?
Jeeples 09-12-2013 01:05 PM
Sadly it appears so.
As for identifying the AD mirror, you should be able to tell a slight difference just in the way they look compared to a non-AD mirror. They have a slight tint to them compared to the passenger side. Aside from that, the wiring harness would be different compared to a regular heated side mirror.
Also, AD was available from '96-'98.
coralman 09-12-2013 04:58 PM
1 Attachment(s)
Two small wires seperate from the main mirror harness. yl/wt and y/bl.
Attachment 671401
caseyliffick 09-13-2013 12:57 AM
That's all it takes is one single signal wire to add the auto dimming feature? I picked up a 96 passenger and driver and rear view mirror and haven't installed the side mirrors because I realized that I only had the three wire piggy backing.
The time now is 05:52 AM.
