Accidentally dumped 5w-30 in the ZJ...Change? - Page 2 - JeepForum.com
post #16 of 42 Old 05-04-2007, 12:07 AM
gregs887
Up your butt Jobu
gregs887's Avatar
Originally Posted by greasefingers
Yup me too. I use 5w-30 during the winter only and 10w-30 for the rest of the year.
Don't mean to hijack, but what would be the benefit of running 5w in the winter and 10w in the summer? Does the 10w not perform as well in colder temperatures?
Greg
Never underestimate the predictability of stupid- Bullet Tooth Tony
gregs887 is offline
post #17 of 42 Old 05-04-2007, 10:24 AM
Double E
Double E's Avatar
Did the image from SJZ in post 5 answer that for you? It's a matter of viscosity (thickness or thinness depending on temp & other factors).
Generally, as temps get colder, liquids flow (or "peform" in an engine) less like water & more like syrup. The same applies to hot weather, but liquids flow more like water than syrup.
So... oil is designed to be used in "anticipated" temps with different ratings like 10w or 5w.
If that's clear enough to understand , the graph will help you from there...
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #18 of 42 Old 05-04-2007, 06:44 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I run which ever is on sale...
2013 FR-S
BlaineWasHere is offline
post #19 of 42 Old 05-05-2007, 07:43 AM
cmonson
I personally run 5-30 in the colder months in the winter.
I run 10-30 all summer.
You will be fine in NJ with 5-30 though.
cmonson is offline
post #20 of 42 Old 11-07-2013, 03:57 PM
DRUMatthias
Thankyas for this thread. Was just about to pose the same question, cuz despite changing radiators, water pumps, Tstats, belts, brakes & other general multi-hour maintenance items on the ol'Blackbird, I leave my oil changes to coupons at Firestone or on rare occasion JLube. Wife had to take it in, as I had lost enough oil that it was barely on the dipstick (and pressure gauge is bouncing a bit...not a good sign I don't believe...another matter at 210K clocked over this week) & they put in 5w30 instead of the standard 10w. It was nice peace of mind to see that pic from the '98 manual about temps as a high temp between now & March is max at about 60*, so I guess they did the right thing, even though I've never had 5w ran in my ZJ before.
Ah well, no need to waste time goin back there or lose a min. of sleep over it now that I know it was kewl kool coolio coolbeans. Cool. Like winter :P
DRUMatthias is offline
post #21 of 42 Old 11-07-2013, 04:23 PM
dnuccio
let me get this straight...you can change brakes, radiators, thermostats, etc, but you dont change your own oil?
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #22 of 42 Old 11-07-2013, 04:45 PM
PolkaPower
I have been using 5w-30 all year around. It's totes kewl.
PolkaPower is offline
post #23 of 42 Old 11-07-2013, 05:29 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Back in the day,lol, they sold reclaimed oil in my town in these pour spout glass jars. I don't think you knew what weight it was. It wasn't going to stay in the beaters long enough to matter.
Originally Posted by HighLonesome
coralman is offline
post #24 of 42 Old 11-08-2013, 07:55 AM
Snowfan2
Thin oil carries heat away from bearings and friction surfaces faster than thick oil. 5-30 might be the best thing to run. I don't go by the owners manual chart viscosity, I go by my climate, use, condition of engine etc.
Snowfan2 is offline
post #25 of 42 Old 11-08-2013, 08:16 AM
PolkaPower
I use the 5w 30 because it's thinner at start up and gets the oil moving around faster in colder weather. It runs the same thickness as 10w 30 after it heats up.
post #26 of 42 Old 11-08-2013, 09:40 AM
4Slow9erHybrid
I run Castrol 0W30 all year round. At operating temperature (210 F) its viscosity is on the higher end of the 30 weight range, at low temperatures it doesn't get as thick as either the 5W30 or 10W30 oils. Only disadvantage is its higher price.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #27 of 42 Old 11-08-2013, 09:40 AM
xcaliber81
I think im running 5-20 cause it was free kewl hey lol. Ill probably be running 5-30 once I have to pay for it which will be soon.
xcaliber81 is offline
post #28 of 42 Old 11-08-2013, 11:43 AM
ROFLwaffles
So wait, you resurrected a 6 1/2 year old thread just to say "thank you"?
ROFLwaffles is offline
post #29 of 42 Old 11-08-2013, 12:22 PM
Timo_90xj
Timo_90xj's Avatar
Same here, I've been using 5W-30 full synth. all year long on my ZJ and used it mostly on both XJs. It usually doesn't get much hotter than ~80-85*F during summer, usually averaging in mid-to high 70s and during winter it's anything between -25 up to around 50*F. No problems at all with oil pressure.
I tried running 10W-30 and 10W-40 on the XJ, didn't really see any difference in oil pressures. That was during summer months though.
Pretty much looks like that's exactly what he did
***Under construction***
Timo_90xj is offline
post #30 of 42 Old 11-08-2013, 04:38 PM
DRUMatthias
You got it straight. I choose to let someone else do it. Cheaper to pay for it to get done than the cost of materials alone for me here. Told ya it's weird but it's how I've rolled for years. Don't think I've changed oil myself in about 7 years or so.
Yup! Got that right too. No need to get cursed for starting a new thread that was already answered & my Thank you reply generated a lot more responses that ultimately kept me from running back to Jiffy Lube & cussin em out for puttin the wrong oil in there, when they seemed to legitimately be going by outside temps as the reason for the 5w adjustment, so that was kewl too! Strength in #s
anybody have dumped flows? Saleen4971 ZJ Grand Cherokee Forum 9 10-02-2010 12:47 PM
Accidentally took apart A/C Mode Selector... canes2088 ZJ Grand Cherokee Forum 3 07-01-2009 01:10 PM
how do i know if i accidentally swapped injector plug wires MEinSoCal ZJ Grand Cherokee Forum 4 06-16-2009 06:18 AM
Accidentally disconnected vacuum line ctwells ZJ Grand Cherokee Forum 10 02-10-2008 02:38 PM
Accidentally fixed my VIC! Wiley ZJ Grand Cherokee Forum 6 11-15-2006 12:02 PM
