AC vent problem - JeepForum.com
post #1 of 3 Old 04-06-2013, 11:25 AM Thread Starter
jeffjeep2
AC vent problem
Hi Guys;
Can you help me find a way to manualy direct the air of the ac in the center vent instead of coming out of the windsheild defrost vent.
Can anybody please also help me where is the black vacuum hose from the T on the engine side ends inside the cabin? ( this hose is the size of a pencil.)
thank you.
jeffjeep2 is offline
post #2 of 3 Old 04-06-2013, 03:17 PM
KoreaZJ
1994 ZJ
Welcome to JF!
Please fill in your Jeep profile info. It displays...
<--- over there.
Black vacuum feed line runs from the firewall to a quick disconnect located (and clipped in) behind the HVAC control panel...
After removing from the clip, the quick disconnect can be pulled out for access...
Manual control type HVAC defaults to defrost when vacuum is low.
Look for a vacuum leak under the hood, go both directions from the t-fitting. Could be a loose fitting, cracked hose, etc.
KoreaZJ is offline
post #3 of 3 Old 06-18-2013, 07:15 AM Thread Starter
jeffjeep2
the black tube to the HVAC was cut thats why i need to manually direct it. when you say clipped. what do you mean?
